Vous Connaissez ?
- Chicotore
Bonjours a tous,
Je suis tombé sur ces deux bébètes et je ne sait pas si vous connaisiez ?
Dragonfly 83
1). Main Rotor Diameter: 900 mm
2). Tail Rotor Diameter: 175 mm
3). Overall Length: 820 mm
4). Engine Model: 15A
5). Battery: 4.8V 650mAh Ni -MH
6). All-up Weight: 1100g (Without fuel)
7). Receiver: RX-702
8). Transmitter: WK-0703
9). Gyro: WK-G007
10).Rudder: weight 9.1g ; speed 0.12sec/60°(4.8V) ;torque 1.1kg/cm (4.8V) ; dimension 22.5X11.8X27mm
11).20g Servo: weight 22.6g ; speed 0.18sec/60°(4.8V) ; torque 2.0kg/cm (4.8V) ; dimension 28.5X13.5X29.6mm
Features
1). CCPM mixing control system and collective pitch structure make perfect 3D aerobatics like rolls, swoop, and inverted flights.
2). Metal rotor head, metal swashplate and metal tail fiber frame structure, built with legerity and novelty. The autorotation landing system, made of high quality one-way bearing, minimizes damage to your helicopter during unplanned landing.
3). Tail blades driven by belt provide easy adjustment, stable flight, and low noise.
4). 15A fuel engine of high performance is powerful.
5). WK-0703 LCD transmitter with adjustable pitch (PIT) parameter, rudder mixing, throttle curve & servo exponential make flight more stably and precisely.
Plus de photos ici => http://www.walkera.com/en1/particular.jsp?pn=Z30830104" onclick="window.open(this.href);return false;
Dragonfly 50
Specification
1). Main rotor Diam.: 675mm
2). Overall height: 425mm
3). Tail rotor Diam.: 250mm
4). All-up weight: 3000g
5). Overall length: 1180mm
6). Drive System: Pro 50 Engine
7). Gyro: WK-CH8
8). Transmitter: WK-1001
9). Receiver: RX801
10). Servo: weight 40g; speed 0.22sec/60o; torque 3.0kg/cm ; dimension 40.8 X20 X36.2mm Features
1). 600mm main rotor blade with high precision and density.
2). All metal swashplate and high-strength principal axis.
3). Special 3D flybar paddle.
4). Enhanced 3 catch points to hold the principle axis.
5). Double Ball-Link-Connector structures.
6). Two-section aluminum exhaust pipe increases the stability and acceleration quality of the engine.
7). Adjustable holder of the tail servo rod.
8). Professional 50 engine, 40g servo.
Plus de photos ici => http://www.walkera.com/en1/particular.jsp?pn=Z30500104" onclick="window.open(this.href);return false;
Vous en pensez quoi ? moi je les trouves plutot pas mal ? et vous savez ou les trouver juste pour connaitre les prix ?
Dragonfly 83
9). Gyro: WK-G007
Features
Dragonfly 50
Specification
7). Gyro: WK-CH8
9). Receiver: RX801
Chicotore made in Le Havre
Haute-normandie
Seine-maritime
76620
Haute-normandie
Seine-maritime
76620
- Eurny666
J'avais vu le Dragonfly 50 et aussi le Dragonfly 7 avec 107 cm au rotor!
13 - Les Pennes Mirabeau / 23 ans DJI F330 TBS style -FPV- (125 vols)
Trex 450 SE -FBL- (223/2) Trex 250 PRO -DFC- (81/3 crashes)
Calmato ST GP 1400 (8/1) Skywalker 1900 -FPV- (20 vols)
Mini Skywalker -FPV- (90 vols) Swift II -FPV- (91 vols)
DX7 / Turnigy 9x + FrSky pour le FPV --- Ultramat 16 / ECO6 / AP6210
RC-Fever :
#83 : 500$
http://www.rc-fever.com/gas-engine-rtf-heli-c-167.html" onclick="window.open(this.href);return false;
#83 : 500$
[img]http://img251.imageshack.us/img251/6373/bladecx2rr8.png[/img]
[img]http://img116.imageshack.us/img116/9258/falconyd4.png[/img]
par contre est-ce que la qualiter de l electronique sur leur thermique est meilleur que sur l electrique tel est la question?
si un servo lache en vol sa va faire plus mal avec 90cm de rotor et moteur thermique
dm4
superskids
speed300
DD helice 4025
pales m24
et
esky belt-cp
lipo2200 25C
brushless 3800KV
radio MX-12
superskids
speed300
DD helice 4025
pales m24
et
esky belt-cp
lipo2200 25C
brushless 3800KV
radio MX-12
Franchement c'est ce point qui me refroidis le plus ^^heliboy92 @ Jun 30 2007, 02:05 PM a écrit : par contre est-ce que la qualiter de l electronique sur leur thermique est meilleur que sur l electrique tel est la question?
Hello ,
A voir la tete rotor , c'est encore une grosse copie du raptor , tout comme le " TZ ", qui lui est un désastre , coté équipement , avec les roulements qui lachent apres quelques vols , moi aussi , je ne me fierais pas a l'électronique .
@+ , claudy ,
Prédator benzin 26cc H - Raptor 50 T - Caliber 30 - Mini titan SE - T7CP
quad Yamaha YFM660R
[img]http://img17.imageshack.us/img17/2778/easypagelogo.jpg[/img]
quad Yamaha YFM660R
en ce qui concerne celui du dessus il ressemble au tz
celui du dessus au raptor
a permeire vue
mais le tz n'a pas la meme tete que le raptor le tz a la barre de bel sous les palles
et le raptor au dessus
a permeire vue
heureux possesseur
d'un t-rex 700LE / t-rex 600n pro/t-rex 450/msh 500 protos/t-rex 250/savage ss 4.6/mp6/hpi elec montee drift/camion perso base mini z/mini lst/moto thunder thiger gonfler moteur trinity 10tours/mini madness
and more......
region de liege belgique
un site helico rc bien belge et francophone
helircbelgium
laeromodelisme.be
No limit no panic the sky is my area of game
- Tuteur sur Heli4.com depuis le 23 Août 2008 [Edit de Bioris]
and more......
helircbelgium
laeromodelisme.be
Ce qui n'empeche pas que les pieces sont compatibles .wilcoyote @ Jun 30 2007, 03:26 PM a écrit :
On y met les pieces raptor pour le fiabiliser ( le TZ )
@+ , claudy ,
quad Yamaha YFM660R
quad Yamaha YFM660R
- Chicotore
Donc en gros c'est de la daube
Haute-normandie
Seine-maritime
76620
Haute-normandie
Seine-maritime
76620
- Eurny666
J'ai vu que Walkera faisaient pour les thermiques de l'électronique de très bonne qualité!
- Chicotore
Quelqu'un serait ou trouver le 50 ? car c'est celui qui me branche le plus , je pense que c'est l'équivalent du raptor ou caliber 50 ? Donc nikel niveau taille
Si vous avez un lien je prend ^^
Haute-normandie
Seine-maritime
76620
Haute-normandie
Seine-maritime
76620
- Eurny666
Sinon tester le dragonfly 83 à la place d'un t-Rex 600 à 1400 complet un peu cher... <_< et lui tout ALU et complet à 500$ chez RC fever, la seule chose qui manque c'est de changer le WK007 par un GY401, c'est tout.
