[HobbyKing] BuddyPrice Code
- FredoLaPower
Qu'est ce que c'est?
Les BuddyPrice Codes sont des liens vers des produits HobbyKing offrant des remises immédiates à celui qui l'utilise. De plus ils font aussi bénéficier à celui qui les partage des Bonus Points. Leur validité est de 14 jours à compter de la date de paiement.
validité: 02/01/2012
TURNIGY Transmitter Strap
Zippy-K Flightmax 850mah 2S1P 20C Lipoly Bat
HobbyKing Cell Key - 6s Lipoly Cell checker
Lithium Polymer Charge Pack 18x22cm Sack
validité: 05/01/2012
Turnigy Typhoon 450H 2218H Heli Motor 3450kv
HK450V2 Canopy
HK450V2 Tail Boom
HK450V2 Skid Nut
450 Size Heli Flybar Paddle White (pair)
450 class Fiberglass Main Blade 325mm
TIG 62mm Carbon Fiber Tail Blade
HK450V2 CF horizontal/vertical tail fin
HK450V2 Carbon Fibre & Alloy Main Frame Asse
HK450V2 Metal Bottom Side Frame
HK450V2 Base Plate
validité: 08/01/2012
FrSky V8HT 2.4Ghz DIY Module
FrSky DF 2.4Ghz Combo Pack for JR w/ Module
Turnigy 9X LCD Backlight Kit - Blue (DIY)
FrSky USB Cable
validité: 09/01/2012
Hobby Mini Saw Set
Knife Edge Reamer 0.5-10mm
X-BLADE Spare SK-5 Steel blades (10pcs/set)
X-BLADE Precision knife with replaceable SK-
HK450V2 Pinion Gear 3.17mm 11T/13T (Align pa
Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)
Turnigy 4mm Heat Shrink Tube Yellow (1mtr)
Turnigy 4mm Heat Shrink Tube - RED (1
Turnigy 5mm Heat Shrink Tube - BLACK (1mtr)
Turnigy 5mm Heat Shrink Tube Yellow (1mtr)
Turnigy 5mm Heat Shrink Tube - RED (1
Female JST battery pigtail 12cm length (10pc
JST Female 2 pin connector set (10pcs/set)
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC
Nylon T-Connectors 10 Pairs (20pc)
validité: 12/01/2012
Turnigy nano-tech 160mah 1S 25~40C Lipo Pack (TREX 100)
Turnigy AA LSD 2200mah Low Self Discharge (r
validité: 15/01/2012
Sponge Wheel D35xH12 (3pcs/bag)
HK-175 Thread Locker & Sealant High Strength
HK-173 Thread Locker & Sealant Permanent (Re
Clear Foam Glue (Medium Cure) - Small 20g
Carbon Fiber Landing Gear 100mm
HK450V2 Canopy
HK450V2 Tail Boom
HK450V2 Skid Nut
HK450V2 Base Plate
FrSky USB Cable
Hobby Mini Saw Set
Modifié en dernier par FredoLaPower le 02 janv. 2012, 12:59, modifié 4 fois.
Veneux les Sablons (77)
Eachine C129 (Firefox)
iCharger 106B+ | NPS700AB (700W/12V/57,6A)
Radiomaster TX16S RealFlight 7.5
[Sud Seine & Marne] Pilotes, spots & clubs
- lionel70
Re: [HobbyKing] BuddyPrice Code
Tu peux aussi les placer sur les liens suivants :
http://hk.rc-international.info/swarm rubrique Buddy Codes (swarn) puis "add buddy codes"
et
http://www.buddyprice.fr.nf/index.php
ça marche plutôt bien
et
- FredoLaPower
Et dire que j'ai vécu sans aussi longtemps
- lionel70
Site : Air et eau, modelisme
- vincenzo
Des lipos nanotech 300mA 1s pour le mcpx.
Achetées le 11-02-2012
Validité + 14jours--> 25-02-2012
Extra Codes, You can save 38.88% for all of this products with:http://www.rc-buddy.com/user/vincenzo! Codes from RC-Buddy.com
[quote]
Turnigy nano-tech 300mah 1S 35c Lipo Pack (Suit Blade mCPx)
Savings: 38.88 % / $1.94
Price after: $3.05
Weight: 20 g
[quote]
Price after: $3.05
Weight: 20 g
- olivier30900
bonjour,
tu fais comment pour utiliser un buddy code ?
optic 6,turnigy 9X néon guru z ac alu,xieda 9958, aile strange planeur et motorisée, simulateur phoenix rc c'est du passé !!!! retour avec bugs 3 radio construteur et passge en mode 2 pour le pilotage
- olivier30900
Il faut déjà être loggé et cliquer sur les liens donnés plus haut.
Le prix apparaît avec un * quand le buddy code est valable.
• Vidéos FPV•
merci ça va me faire des économies ça et comment obtient on un code pour le mettre en ligne ?
- vincenzo
Déja il faut faire une commande, et tous les produits ne sont pas concernés. Tu vas dans l'historique de ta commande, si à coté de l'article apparait un icône bleu, tu click sur l'icone et ça te donne un code. Ce code est valable 14 jours, à raison de 3 articles maxi par commande.
alors voici mes buddy code dispo
Turnigy nano-tech 160mah 1S 25~40C Lipo Pack (Kyosho, E-flite, Parkzone Etc)
http://www.hobbyking.com/buddy.asp?code ... DA82188E07
HobbyKing HK-190 2.4ghz 4Ch Fixed Pitch Helicopter (RTF-Mode 1)
http://www.hobbyking.com/buddy.asp?code ... CF479048FB
2 Pin 6 x Pico Plug Charging Set Eflite compatible.
http://www.hobbyking.com/buddy.asp?code ... D4EAC0AB5D
encore une chose ou trouver son buddy name ?
up
personne pour alimenter ?
- MaYeuT
Turnigy 3000mAh 6S 40C Lipo Pack (DE Warehouse):
http://www.hobbyking.com/buddy.asp?code ... 7E16ECCFEA
Marne (51) - 35 ans
Graupner MZ24
Hyperion Duo+
RF 7.5 & Next
Lynx Team Pilot
Graupner MZ24
Hyperion Duo+
RF 7.5 & Next
Lynx Team Pilot
Quelques codes: http://hk.rc-international.info/swarm/chriscool (valables jusqu'au 30 mars 2012)
Hobbyking HeliDrive 100A (2~6S) SBEC Brushless Speed Controller Save US$: 10.18
Scale alloy hub rubber wheel 2.5inch Save US$: 1.41
Turnigy Servo Signal Reverser Save US$: 0.41
Turnigy Ultra-light wood propeller 16x8 Save US$: 0.64
Turnigy AA LSD 2200mah Low Self Discharge (ready to use) Save US$: 0.14
SF E-Prop 10x3.8 / 254x96.5mm w/ Adapters Black (5pcs/set) Save US$: 0.80
BMS-621MG High Speed Servo (Metal Gear) 6.4kg / .13sec / 47g Save US$: 11.48
Turnigy Aerodrive SK3 - 42-XX Spare Accessory Pack Save US$: 1.70
Turnigy Aerodrive SK3 4250 Series Replacement Shaft Set Save US$: 1.25
Stand Off Mounts (4pc) 20mm Save US$: 1.07
- ARushOfBlood
Voilà ceux que je peux faire partager :
HK-500GT Main Gear Assembly (Align part) > $6.17
HK-500GT Metal Tail Drive Gear set (Align part) > $2.44
Training Gear for 450 Class Helicopter > $2.48
Hobby King 401B AVCS Digital Head Lock Gyro > $9.70
325mm Glass Fiber Main Blades (Blue/white) > $4.24
De retour
- cammi
quelques buddy code :
-Turnigy nano-tech 2200mah 3S 35~70C Lipo Pack
-Turnigy nano-tech 1600mah 2S 25~50C Lipo Pack
-Hands free item holder
Voilà, bonne journée.
Gaui 425 => 500 , powered bye Microbeast/YGE80A /Z20A 980KV
quelques codes de plus :
HobbyKing HK-922MG Digital Metal Gear Servo 1.8kg/ 12g/ 0.07sec Save US$: 2.89
HK15158A Digital BB/Coreless Mini Servo 25g / 2.8kg / 0.07s Save US$: 0.52
High Density Waterproof LED Flexible Strip - White (1mtr) Save US$: 2.59
ZYX-S 3-Axis Flybarless System w/USB Program Adapter Save US$: 12.48
ZYX-S DSM2/DSMJ Satellite Receiver Cable Save US$: 1.48
High Density Waterproof LED Flexible Strip - RED (1mtr) Save US$: 2.59
Turnigy Pure-Silicone Wire 14AWG (1mtr) RED Save US$: 0.54
Turnigy AA Ni-ZN 1500mAh High Voltage (ready to use) Save US$: 1.32
turnigy accucel à 24 $ en DE warehouse soit 40% de réductions j'en ai bénéficier mais je n'ai pas eu de buddy code
http://www.hobbyking.com/hobbyking/stor ... 4953427C7B
il est valable encore environ 8 jours je pense
Trex 450 se v2 , MCPX
DX6I mode 2
Turnigy accucel 6
DX6I mode 2
Turnigy accucel 6
Lippos turnigy 3S 2200 40C a un peu moins cher (valable 15 jours): http://www.hobbyking.com/buddy.asp?code ... C216B2D48A
Idem pour des 2S 800 20C http://www.hobbyking.com/buddy.asp?code ... 50D6DCF696
Pour ceux que ça intéresse...
ZIPPY Flightmax 2200mAh 3S1P 40C (DE Warehouse)
http://www.hobbyking.com/buddy.asp?code ... C0D5DDAEE6
Patrick... tu me diras comment pour les frais de douane Suisse pour les commandes DE
Merci...
Merci...
- LE 59
Bonsoir
HK-500GT Metal Tail Drive Gear set (Align part # H50043):http://www.hobbyking.com/buddy.asp?code ... 55B3C3BA8D
HK-500GT Feathering Shaft (Align part # H50023):http://www.hobbyking.com/buddy.asp?code ... DA2A2D6D53
HKF-021 Neon fibre de verre jaune horizontale / verticale F:http://www.hobbyking.com/buddy.asp?code ... 186F2D1816.
J y penses jamais
J y penses jamais
- lolo09
si vous avez ou allez avoir des lippo TP et que vous etes équipé en XT60
voilou...
XT60 - JST Female in-line power adapter http://www.hobbyking.com/buddy.asp?code ... E7496A36D5
Hobbyking Parallel charging Board for 6 pack http://www.hobbyking.com/buddy.asp?code ... 792CB319E1
Male JST-XH <-> Female Thunderpower 2S 5cm http://www.hobbyking.com/buddy.asp?code ... E366B01B41
voilou...
Un peu de matos pour bricoler un quad maison (valide > 7 novembre 2012).
Il y a aussi un p'tit prix sur les NTM 2826 1200KV et un sac de transport pour glider style Bixler, AXN, EasyStar et Cie.
Enjoy!
Enjoy!
- LE 59
Bonjour ,
Petite remise sur HK 600,et lipo 5000 mAh 30C et d autre choses...
Valable jusqu’au 11/11/2012
HK-500GT Metal Tail Drive Gear set (Align part # H50043) Save US$: 2.16
Futaba Servo Arm Set Save US$: 1.25
HK600GT landing skid (H60039) Save US$: 0.23
Tail Blades Plastic HK-550GT Save US$: 1.28
HK-500GT Feathering Shaft (Align part # H50023) Save US$: 0.82
Neon Yellow Fiberglass Horizontal/Vertical Fins Trex 500 Save US$: 0.87
HK-600GT 3D Electric Helicopter Kit w/o blades (DE Warehouse) Save US$: 15.10
Turnigy 5000mAh 6S 30C Lipo Pack (DE Warehouse) Save US$: 20.93
TURNIGY K-Force 100A Brushless ESC (DE Warehouse) Save US$: 5.85
HK600GT tail blade (H60051) Save US$: 0.15
HK600GT main shaft (H60013-1) Save US$: 0.50
HK600GT stabilizer bar (H60108) Save US$: 0.26
Browse buddycodes on RC International now with your Android mobile phone or tablet with RC International unoffcial Hobbyking app
- LE 59
Hello
until November 26, 2012[/B])
Servo Terminals (JR) Gold Plated (10pairs/set) Save US$: 0.57
Twisted 22AWG servo wire 1mtr (R/B/Y) 22AWG Save US$: 0.67
4MM Banana Plug / Charge Plug (solder type) (2 pair/bag) Save US$: 0.59
Ah, mes pales préférées en 450 à moins de 3$ la paire, vont bientôt les donner
http://www.hobbyking.com/buddy.asp?code ... 5B91517AB7
Find my codes here: http://hk.rc-international.info/swarm/specter_03 (valid until December 27, 2012)
JST-XH Parallel Balance Lead 4S 250mm (6xJST-XH) Save US$: 0.56
JST-XH Parallel Balance Lead 6S 250mm (6xJST-XH) Save US$: 1.79
JST-XH Parallel Balance Lead 3S 250mm (6xJST-XH) Save US$: 0.51
Magnetizer/Demagnetizer Tool Save US$: 0.48
RG58 Patch Cable SMA Female to SMA Male (1 Meter) Save US$: 1.36
Turnigy Transmitter Bag / Carrying Case Save US$: 1.80
- LE 59
Bonjour a tous
until January 11, 2013[/B])
Turnigy Hex Driver set 1.5~ 3.0 Save US$: 0.64
Turnigy Transmitter Bag / Carrying Case : elle est vraiment bien ,ma DX8 est satisfaite merci Specter
- LE 59
bonsoir
JR & Spektrum Satellite Receiver Extension Wire 60 & 90cm
http://hk.rc-international.info/swarm/le59
- vincenzo
yo,
ImmersionRC 5.8Ghz Audio/Video Transmitter - FatShark compatible (600mw) Save US$: 2.65
http://www.hobbyking.com/buddy.asp?code ... F4B9E20DEE
- LE 59
Axes pieds de pales pour tete RJX
Find my codes here: http://hk.rc-international.info/swarm/le59 (valid until February 22, 2013)
8mm Spindle for Align T-rex600 and 50 size Save US$: 1.29
- LE 59
Cables,prises ....
Find my codes here: http://hk.rc-international.info/swarm/le59 (valid until April 09, 2013)
430mm Carbon Fiber Helicopter Main Blades Save US$: 1.21
Turnigy Pure-Silicone Wire 10AWG (1mtr) BLACK Save US$: 0.68
Turnigy Pure-Silicone Wire 10AWG (1mtr) RED Save US$: 0.68
Turnigy 6mm Heat Shrink Tube - BLACK (1mtr) Save US$: 0.28
Turnigy 6mm Heat Shrink Tube - Save US$: 0.22
Mini Tamiya Female Connector (10pcs/set) Save US$: 0.03
Mini Tamiya Connector Male (10pcs/bag) Save US$: 0.27
Bon vols
LE59
Cables,prises ....
Bon vols
LE59
Servos turnigy 306 G avec 3,38$ de réduc, ça fait plus de 13,50$ de moins sur le jeu de 4 : http://www.hobbyking.com/buddy.asp?code ... 56D824084B
Edit : Bon, je viens de voir que j'avais du prendre les derniers... désolé
Mais surtout que les buddy code sont valable que pour une pièce...
Envoyé de mon iPad à l'aide de Tapatalk HD
Ah oui, si y faut faire commander tous les copains pour en avoir un jeu, cela va pas simplifier...
- Xpower51
Mes dernières commandes d'il y a 2 jours :
- Moteur NTM Series 28-26A 1200kv en provenance d'Allemagne : http://www.hobbyking.com/buddy.asp?code ... 132C66A7B9 $13.93 au lieu de $15.69
- FrSky D8R-II PLUS 2.4Ghz 8CH Receiver with Telemetery : http://www.hobbyking.com/buddy.asp?code ... A12CA99571 $23.00 au lieu de $23.95
- FrSky DHT 8ch DIY Telemetry Compatible Transmitter Module : http://www.hobbyking.com/buddy.asp?code ... 5CD8B46A4E $20.38 au lieu de $21.56
- FrSky 2.4G V8 Series 5db module Antenna : http://www.hobbyking.com/buddy.asp?code ... DE14707121 $2.00 au lieu de $2.71
- vivazapata
SalutSpecter_03 a écrit :Mais surtout que les buddy code sont valable que pour une pièce...
Tu peux prendre 3 articles ( les 3 mêmes par contre )
Roche la moliere prés de Saint etienne 42
Easycoptere V6 ; walkera 5G6 ; walkera LAMA3; walkera LAMA400
CB100 ; CB 180D ; V200D01
DRAGONUS Elite ; HK 450 ;CopterX 450 ;Walkera V120D02 ; Blade MCPX
GAUI 330XS ;Q450 carte KK2LCD ; F330 NAZA lite ; DJI450 NAZA +GPS ; Blade MQX ; U816 ; Hubsan X4 FPV ; Phantom V1.1.1
2xWK 2801 pro ;DX8
En plus.............CARPISTE
2xWK 2801 pro ;DX8
- helipat1952
Recepteur et satellite orange ( NL )
Satellite: http://www.hobbyking.com/hobbyking/stor ... duct=31435
http://www.hobbyking.com/buddy.asp?code ... FE7A26412A
Recepteur R710: http://www.hobbyking.com/hobbyking/stor ... duct=39537
Radio: DX6i, DX9
Simu: Phoenix V4
Radio: DX6i, DX9
Simu: Phoenix V4
