[HobbyKing] BuddyPrice Code
FredoLaPower
Message par FredoLaPower » 01 janv. 2012, 21:36
Qu'est ce que c'est?
Les BuddyPrice Codes sont des liens vers des produits HobbyKing offrant des remises immédiates à celui qui l'utilise. De plus ils font aussi bénéficier à celui qui les partage des Bonus Points. Leur validité est de 14 jours à compter de la date de paiement.
validité: 02/01/2012
TURNIGY Transmitter Strap
Zippy-K Flightmax 850mah 2S1P 20C Lipoly Bat
HobbyKing Cell Key - 6s Lipoly Cell checker
Lithium Polymer Charge Pack 18x22cm Sack
validité: 05/01/2012
Turnigy Typhoon 450H 2218H Heli Motor 3450kv
HK450V2 Canopy
HK450V2 Tail Boom
HK450V2 Skid Nut
450 Size Heli Flybar Paddle White (pair)
450 class Fiberglass Main Blade 325mm
TIG 62mm Carbon Fiber Tail Blade
HK450V2 CF horizontal/vertical tail fin
HK450V2 Carbon Fibre & Alloy Main Frame Asse
HK450V2 Metal Bottom Side Frame
HK450V2 Base Plate
validité: 08/01/2012
FrSky V8HT 2.4Ghz DIY Module
FrSky DF 2.4Ghz Combo Pack for JR w/ Module
Turnigy 9X LCD Backlight Kit - Blue (DIY)
FrSky USB Cable
validité: 09/01/2012
Hobby Mini Saw Set
Knife Edge Reamer 0.5-10mm
X-BLADE Spare SK-5 Steel blades (10pcs/set)
X-BLADE Precision knife with replaceable SK-
HK450V2 Pinion Gear 3.17mm 11T/13T (Align pa
Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)
Turnigy 4mm Heat Shrink Tube Yellow (1mtr)
Turnigy 4mm Heat Shrink Tube - RED (1
Turnigy 5mm Heat Shrink Tube - BLACK (1mtr)
Turnigy 5mm Heat Shrink Tube Yellow (1mtr)
Turnigy 5mm Heat Shrink Tube - RED (1
Female JST battery pigtail 12cm length (10pc
JST Female 2 pin connector set (10pcs/set)
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC
Nylon T-Connectors 10 Pairs (20pc)
validité: 12/01/2012
Turnigy nano-tech 160mah 1S 25~40C Lipo Pack (TREX 100)
Turnigy AA LSD 2200mah Low Self Discharge (r
validité: 15/01/2012
Sponge Wheel D35xH12 (3pcs/bag)
HK-175 Thread Locker & Sealant High Strength
HK-173 Thread Locker & Sealant Permanent (Re
Clear Foam Glue (Medium Cure) - Small 20g
Carbon Fiber Landing Gear 100mm
Modifié en dernier par FredoLaPower le 02 janv. 2012, 12:59, modifié 4 fois.
Image Veneux les Sablons (77)
Image -
Image Eachine C129 (Firefox)
Image iCharger 106B+ | NPS700AB (700W/12V/57,6A)
Image Radiomaster TX16S Image RealFlight 7.5
[Sud Seine & Marne] Pilotes, spots & clubs
lionel70
Re: [HobbyKing] BuddyPrice Code
Message par lionel70 » 01 janv. 2012, 21:47
Tu peux aussi les placer sur les liens suivants :
http://hk.rc-international.info/swarm rubrique Buddy Codes (swarn) puis "add buddy codes"
et
http://www.buddyprice.fr.nf/index.php
ça marche plutôt bien ;)
MCPX V1
FredoLaPower
Message par FredoLaPower » 01 janv. 2012, 22:59
Et dire que j'ai vécu sans aussi longtemps :D
Image -
lionel70
Message par lionel70 » 01 janv. 2012, 23:07
;) :D
MCPX V1
den
Pipelette
Message par den » 02 janv. 2012, 12:10
Des axes principaux et des courroies 450V2 pour crasher à gogo en 2012 ? ;)
validité 14/01
vincenzo
Message par vincenzo » 11 févr. 2012, 22:30
Des lipos nanotech 300mA 1s pour le mcpx.
Achetées le 11-02-2012
Validité + 14jours--> 25-02-2012
Extra Codes, You can save 38.88% for all of this products with:http://www.rc-buddy.com/user/vincenzo! Codes from RC-Buddy.com
[quote]
Turnigy nano-tech 300mah 1S 35c Lipo Pack (Suit Blade mCPx)
Savings: 38.88 % / $1.94
Price after: $3.05
Weight: 20 g
olivier30900
Message par olivier30900 » 11 févr. 2012, 23:13
Le RX 9 voies orange spektrum : http://www.hobbyking.com/buddy.asp?code ... E3005E4B1F
Vidéos FPV
kite17
Message par kite17 » 12 févr. 2012, 19:22
bonjour,
tu fais comment pour utiliser un buddy code ?
optic 6,turnigy 9X néon guru z ac alu,xieda 9958, aile strange planeur et motorisée, simulateur phoenix rc c'est du passé !!!! retour avec bugs 3 radio construteur et passge en mode 2 pour le pilotage
olivier30900
Message par olivier30900 » 12 févr. 2012, 19:27
Il faut déjà être loggé et cliquer sur les liens donnés plus haut.
Le prix apparaît avec un * quand le buddy code est valable.
Vidéos FPV
kite17
Message par kite17 » 12 févr. 2012, 19:46
merci ça va me faire des économies ça et comment obtient on un code pour le mettre en ligne ?
vincenzo
Message par vincenzo » 12 févr. 2012, 20:01
Déja il faut faire une commande, et tous les produits ne sont pas concernés. Tu vas dans l'historique de ta commande, si à coté de l'article apparait un icône bleu, tu click sur l'icone et ça te donne un code. Ce code est valable 14 jours, à raison de 3 articles maxi par commande.
kite17
Message par kite17 » 12 févr. 2012, 20:10
alors voici mes buddy code dispo
Turnigy nano-tech 160mah 1S 25~40C Lipo Pack (Kyosho, E-flite, Parkzone Etc)
http://www.hobbyking.com/buddy.asp?code ... DA82188E07
HobbyKing HK-190 2.4ghz 4Ch Fixed Pitch Helicopter (RTF-Mode 1)
http://www.hobbyking.com/buddy.asp?code ... CF479048FB
2 Pin 6 x Pico Plug Charging Set Eflite compatible.
http://www.hobbyking.com/buddy.asp?code ... D4EAC0AB5D
encore une chose ou trouver son buddy name ?
kite17
Message par kite17 » 15 févr. 2012, 01:05
up
personne pour alimenter ?
MaYeuT
Message par MaYeuT » 15 févr. 2012, 23:23
Turnigy 3000mAh 6S 40C Lipo Pack (DE Warehouse):
http://www.hobbyking.com/buddy.asp?code ... 7E16ECCFEA
Marne (51) - 35 ans
Graupner MZ24
Hyperion Duo+
RF 7.5 & Next
Lynx Team Pilot
ARushOfBlood
Message par ARushOfBlood » 31 mars 2012, 21:39
De retour :wub:
cammi
Sergent
Message par cammi » 01 juil. 2012, 10:04
Gaui 425 => 500 , powered bye Microbeast/YGE80A /Z20A 980KV
alex2601
Sergent
Message par alex2601 » 02 août 2012, 10:34
turnigy accucel à 24 $ en DE warehouse soit 40% de réductions j'en ai bénéficier mais je n'ai pas eu de buddy code
http://www.hobbyking.com/hobbyking/stor ... 4953427C7B
il est valable encore environ 8 jours je pense
Image Trex 450 se v2 , MCPX
Image DX6I mode 2
Image Turnigy accucel 6
perrus53
Message par perrus53 » 01 oct. 2012, 00:27
Lippos turnigy 3S 2200 40C a un peu moins cher (valable 15 jours): http://www.hobbyking.com/buddy.asp?code ... C216B2D48A
Idem pour des 2S 800 20C :) http://www.hobbyking.com/buddy.asp?code ... 50D6DCF696
Image Page perso
Image Laval (53)
Image Trex 450SE - DS410 - LTG2100T
Image Lama V4
Image Spektrum DX6i
Image RF G4
Specter_03
Message par Specter_03 » 21 oct. 2012, 08:12
Pour ceux que ça intéresse... ;)
ZIPPY Flightmax 2200mAh 3S1P 40C (DE Warehouse)
http://www.hobbyking.com/buddy.asp?code ... C0D5DDAEE6
chriscool
Message par chriscool » 21 oct. 2012, 09:54
Patrick... tu me diras comment pour les frais de douane Suisse pour les commandes DE ;)
Merci...
LE 59
Message par LE 59 » 21 oct. 2012, 18:41
Bonsoir
HK-500GT Metal Tail Drive Gear set (Align part # H50043):http://www.hobbyking.com/buddy.asp?code ... 55B3C3BA8D
HK-500GT Feathering Shaft (Align part # H50023):http://www.hobbyking.com/buddy.asp?code ... DA2A2D6D53
HKF-021 Neon fibre de verre jaune horizontale / verticale F:http://www.hobbyking.com/buddy.asp?code ... 186F2D1816.
J y penses jamais :(
A+ JP
Image Neuville en ferrain,NORD
Image DX8
Dominator,HK600 +fuselage Airwolf (en cour de réparation :))
ImageHyperion EOS 720i SuperDuo 3 / reaktor/ Alim 83 A
Image Phoenix Rc
lolo09
Message par lolo09 » 23 oct. 2012, 20:02
si vous avez ou allez avoir des lippo TP et que vous etes équipé en XT60
voilou...
XT60 - JST Female in-line power adapter http://www.hobbyking.com/buddy.asp?code ... E7496A36D5
Hobbyking Parallel charging Board for 6 pack http://www.hobbyking.com/buddy.asp?code ... 792CB319E1
Male JST-XH <-> Female Thunderpower 2S 5cm http://www.hobbyking.com/buddy.asp?code ... E366B01B41
What else !?
Image DX8 Image NeXt, RF 7
chriscool
Message par chriscool » 24 oct. 2012, 14:20
Un peu de matos pour bricoler un quad maison (valide > 7 novembre 2012).
Il y a aussi un p'tit prix sur les NTM 2826 1200KV et un sac de transport pour glider style Bixler, AXN, EasyStar et Cie.
Enjoy! ;) ^_^
LE 59
Message par LE 59 » 28 oct. 2012, 14:34
Bonjour ,
Petite remise sur HK 600,et lipo 5000 mAh 30C et d autre choses...
Valable jusqu’au 11/11/2012
HK-500GT Metal Tail Drive Gear set (Align part # H50043) Save US$: 2.16
Futaba Servo Arm Set Save US$: 1.25
HK600GT landing skid (H60039) Save US$: 0.23
Tail Blades Plastic HK-550GT Save US$: 1.28
HK-500GT Feathering Shaft (Align part # H50023) Save US$: 0.82
Neon Yellow Fiberglass Horizontal/Vertical Fins Trex 500 Save US$: 0.87
HK-600GT 3D Electric Helicopter Kit w/o blades (DE Warehouse) Save US$: 15.10
Turnigy 5000mAh 6S 30C Lipo Pack (DE Warehouse) Save US$: 20.93
TURNIGY K-Force 100A Brushless ESC (DE Warehouse) Save US$: 5.85
HK600GT tail blade (H60051) Save US$: 0.15
HK600GT main shaft (H60013-1) Save US$: 0.50
HK600GT stabilizer bar (H60108) Save US$: 0.26
Browse buddycodes on RC International now with your Android mobile phone or tablet with RC International unoffcial Hobbyking app
A+ JP
Image DX8
Image Phoenix Rc
LE 59
Message par LE 59 » 12 nov. 2012, 18:41
A+ JP
Image DX8
Image Phoenix Rc
den
Pipelette
Message par den » 21 nov. 2012, 22:06
Ah, mes pales préférées en 450 à moins de 3$ la paire, vont bientôt les donner ;)
http://www.hobbyking.com/buddy.asp?code ... 5B91517AB7
Specter_03
Message par Specter_03 » 13 déc. 2012, 16:35
Find my codes here: http://hk.rc-international.info/swarm/specter_03 (valid until December 27, 2012)
JST-XH Parallel Balance Lead 4S 250mm (6xJST-XH) Save US$: 0.56
JST-XH Parallel Balance Lead 6S 250mm (6xJST-XH) Save US$: 1.79
JST-XH Parallel Balance Lead 3S 250mm (6xJST-XH) Save US$: 0.51
Magnetizer/Demagnetizer Tool Save US$: 0.48
RG58 Patch Cable SMA Female to SMA Male (1 Meter) Save US$: 1.36
Turnigy Transmitter Bag / Carrying Case Save US$: 1.80
LE 59
Message par LE 59 » 28 déc. 2012, 12:34
Bonjour a tous
until January 11, 2013[/B])
Turnigy Hex Driver set 1.5~ 3.0 Save US$: 0.64
Twisted 22AWG servo wire 1mtr (R/B/Y) 22AWG Save US$: 0.67
Turnigy Transmitter Bag / Carrying Case : elle est vraiment bien ,ma DX8 est satisfaite merci Specter
A+ JP
Image DX8
Image Phoenix Rc
LE 59
Message par LE 59 » 07 févr. 2013, 00:14
bonsoir
JR & Spektrum Satellite Receiver Extension Wire 60 & 90cm
http://hk.rc-international.info/swarm/le59
A+ JP
Image DX8
Image Phoenix Rc
vincenzo
Message par vincenzo » 07 févr. 2013, 09:20
LE 59
Message par LE 59 » 08 févr. 2013, 01:41
Axes pieds de pales pour tete RJX
Find my codes here: http://hk.rc-international.info/swarm/le59 (valid until February 22, 2013)
8mm Spindle for Align T-rex600 and 50 size Save US$: 1.29
A+ JP
Image DX8
Image Phoenix Rc
LE 59
Message par LE 59 » 26 mars 2013, 12:24
Cables,prises ....
Find my codes here: http://hk.rc-international.info/swarm/le59 (valid until April 09, 2013)
430mm Carbon Fiber Helicopter Main Blades Save US$: 1.21
Turnigy Pure-Silicone Wire 10AWG (1mtr) BLACK Save US$: 0.68
Turnigy Pure-Silicone Wire 10AWG (1mtr) RED Save US$: 0.68
Turnigy 6mm Heat Shrink Tube - BLACK (1mtr) Save US$: 0.28
Turnigy 6mm Heat Shrink Tube - Save US$: 0.22
Mini Tamiya Female Connector (10pcs/set) Save US$: 0.03
Mini Tamiya Connector Male (10pcs/bag) Save US$: 0.27
Bon vols
LE59
A+ JP
Image DX8
Image Phoenix Rc
den
Pipelette
Message par den » 28 mars 2013, 01:43
Servos turnigy 306 G avec 3,38$ de réduc, ça fait plus de 13,50$ de moins sur le jeu de 4 : http://www.hobbyking.com/buddy.asp?code ... 56D824084B
Edit : Bon, je viens de voir que j'avais du prendre les derniers... désolé :rolleyes:
Specter_03
Message par Specter_03 » 28 mars 2013, 09:56
Mais surtout que les buddy code sont valable que pour une pièce... :(
Envoyé de mon iPad à l'aide de Tapatalk HD
den
Pipelette
Message par den » 28 mars 2013, 14:02
Ah oui, si y faut faire commander tous les copains pour en avoir un jeu, cela va pas simplifier...
Xpower51
Caporal
Message par Xpower51 » 08 mai 2013, 11:08
Mes dernières commandes d'il y a 2 jours :
- Moteur NTM Series 28-26A 1200kv en provenance d'Allemagne : http://www.hobbyking.com/buddy.asp?code ... 132C66A7B9 $13.93 au lieu de $15.69
- FrSky D8R-II PLUS 2.4Ghz 8CH Receiver with Telemetery : http://www.hobbyking.com/buddy.asp?code ... A12CA99571 $23.00 au lieu de $23.95
- FrSky DHT 8ch DIY Telemetry Compatible Transmitter Module : http://www.hobbyking.com/buddy.asp?code ... 5CD8B46A4E $20.38 au lieu de $21.56
- FrSky 2.4G V8 Series 5db module Antenna : http://www.hobbyking.com/buddy.asp?code ... DE14707121 $2.00 au lieu de $2.71
vivazapata
Message par vivazapata » 08 mai 2013, 17:07
Specter_03 a écrit :Mais surtout que les buddy code sont valable que pour une pièce... :(
Tu peux prendre 3 articles ( les 3 mêmes par contre ) ;)
Image Roche la moliere prés de Saint etienne 42
Image Easycoptere V6 ; walkera 5G6 ; walkera LAMA3; walkera LAMA400
ImageCB100 ; CB 180D ; V200D01
ImageDRAGONUS Elite ; HK 450 ;CopterX 450 ;Walkera V120D02 ; Blade MCPX
Image GAUI 330XS ;Q450 carte KK2LCD ; F330 NAZA lite ; DJI450 NAZA +GPS ; Blade MQX ; U816 ; Hubsan X4 FPV ; Phantom V1.1.1
Image2xWK 2801 pro ;DX8
En plus.............CARPISTE Image Image
helipat1952
Message par helipat1952 » 08 mai 2013, 17:15
Radio: DX6i, DX9
Simu: Phoenix V4
Retourner vers « Bla Bla... »
