Lipo Génération 3
Coucou,
Bon, dernierement Oli avait parlé des nouvelles lipo Hyperion , lipo génération3 :
Avec google translate :
Voilà
Quelques liens :
Dimensions et spécifications des lipos G3 Hyperion
________________________
EDIT :
Pour ceux qui veulent recharger une 3S Hyperion sur une plaquette d'équilibrage NON hyperion, voici l'astuce qui a été posté par PatDM sur un autre sujet
_________________________
Hyperion Generation 3 Lithium Polymer Packs are proving truly revolutionary in both performance and value. Compared to an average of the batteries on market last year, they provide up to up to 4x more cycles under the same discharge conditions. And that makes them a bargain price-wise.
But they also deliver the highest voltage and flattest discharge curves under load that we have ever seen, which makes them the best performer you can buy. And tests have shown that at the 70%-discharged point in flight, they are delivering as much as 40% more power than previous generation LiPo.
The fact that they can be safely charged at up to 5C rates - for charge times as low as 10 to 12 minutes - is just icing on a very tasty cake.
The G3 packs are made with a new Hybrid RS construction technology, super-fine substrate materials, rigorous ISO 9001 Quality Control, and final cell matching process, which all guarantee you not only this superb performance, but also tightly balanced and long-lasting packs.
The G3 LiPo come in two series. "CX" 25C are appropriate for most models and deliver high capacity and power per gram at low cost. The "VX" 35C series is the one for applications that need the highest possible voltage maintained at high discharge rates; for example highly aerobatic 3D airplanes and helicopters, competition gliders, pylon racers, and some EDF jets.
Check'm out, you'll be glad you did.
Hyperion Generation 3 Packs Lithium Polymer s'avèrent véritablement révolutionnaire à la fois la performance et de valeur. Par rapport à la moyenne des piles sur le marché l'an dernier, ils fournissent jusqu'à jusqu'à 4x plus de cycles de décharge dans les mêmes conditions. Et cela fait d'eux un prix-sage.
Mais ils ont aussi fournir la plus haute tension et de décharge plate courbes en charge que nous avons jamais vu, qui fait d'eux les meilleurs résultats, vous pouvez acheter. Et des tests ont montré que 70% au-point déchargé en vol, ils fournissent jusqu'à 40% plus de puissance que la génération précédente LiPo.
Le fait qu'ils peuvent être facturés à des taux allant jusqu'à 5C - pour sa charge que 10 à 12 minutes - est juste la cerise sur un gâteau savoureux.
Le G3 packs sont faits avec une nouvelle technologie de la construction hybride RS, super-fine substrats, rigoureux contrôle de la qualité ISO 9001, et dernier processus de cellule, qui garantissent non seulement vous cette superbe performance, mais également bien équilibré et durable packs .
Le G3 LiPo sont de deux séries. "CX" 25C sont appropriés pour la plupart des modèles et de haute capacité et le pouvoir par gramme à bas prix. Le "VX" 35C est une série pour les applications qui en ont besoin le plus élevé possible, la tension maintenue à des taux élevés de décharge, par exemple, très acrobatique 3D des avions et des hélicoptères, à la concurrence les planeurs, les coureurs pylône, EDF et certains jets.
Check'm, vous serez heureux que vous l'avez fait.
Voilà
Quelques liens :
EDIT :
PatTDM @ 5 Nov 2009, à 00:29 a écrit : ce que j'ai fait :
j'ai déplacé les fils sur la prise d'équilibrage, je branche sur la prise 4S de ma plaquette d'équilibrage et je déclare normalement la lipo sur le chargeur (xxx mAh, 3S)![]()
A gauche, la fiche d'origine. A droite, la fiche modifiée.7
Comme ça, j'ai pas eu besoin d'acheter une autre plaquette d'équilibrage !!!
Bon.... y a pas foule de réponse
du coup, je passe commande demain pour une 4S.... et je vous dirai quoi apres
Enfin, si je la recoi
Si je peu l'avoir pour le meeting Heli4 ca serai bien
Rendons à César ce qui est à César ..GégéPilote @ 16 Apr 2009, à 16:40 a écrit : Coucou,
Mais c'est vrai que ca faisait qq tps que nous deux les attendions.
En effet en mettant à jour les firmware de nos chargeurs Hyperion j'avais remarqué que la limite de 5C pour les lipo et la venue fin avril de ces nouveaux packs !
Voilà pour la précision.
A savoir si elles vont remplacer ... A voir.Pour ma part je pense que oui.
- RolluS
- Tuteur - Webmaster
Ca sent le LiMnO2 non? Ca reste du lithium, mais avec le substrat qui change... Et justement ils en parle..
Car Leselectrode au Cobalt (LiPo), y'a pas a foutre, la chimie fera pas de miracle, quand c'est bouffé, c'est bouffé...
A mon avis la duée de vie (pas le cyclage) ne sera pas augmentée si c'est réellement une Technologie LiPo. Le cyclage oui, la durée de vie (18 mois) non..
En tout cas, même si la durée de vie n'est pas plus longue.... vu le prix... et le perfs... pour ceux qui vole beaucoup ou pas, ca restera plus valable que les lipo avtuelles.
En tous cas j'attends de voir.
Pour ca, j'ai demandé l'annulation d'une commande de lipo sur HB pour prendre une hyperion pour commencer afin de voir
Par contre, ca sera pour moi une 4S en 4000mhA.... wait and see
je epsne que je vais m'en prendre une ou duex pour mon drag quand elles seront de stock, j'ai annulé des vplus car elles ont l'air bien meiux.
[img]http://goodies.heli4.com/icones/drapo_be.png[/img]Liège/Bruxelles , 27 ans - Geek à plein temps
[img]http://goodies.heli4.com/icones/fp.png[/img]Compy - ESKY brushless 3900kv-ESC Dynam 25A-AR6100
[img]http://goodies.heli4.com/icones/cp.png[/img] H550 gy 401,DS610, A123 [img]http://nsa03.casimages.com/img/2009/01/09/090109121541243282.png[/img] Phoenix rc 2
[img]http://goodies.heli4.com/icones/radio.png[/img]DX6I [img]http://goodies.heli4.com/icones/charger.png[/img]Imax B6 * hyperion 720i
Tu en as avec toi Oli des hyperion déjà ?Oli @ 21 Apr 2009, à 06:32 a écrit : Tu peux pas supposer comme ca Rollus
Moi j'utilise dans monREx500 un pack qui a 12 mois
Mais eux ne compte pas en mois mais en nombre de cycle et annoncent 5 fois plus.
On aura la réponse après les avoir utilisé intensivement une année.
Non.. Le mois prochain pt'etre
Le modèle que je visais était en rupture.
Mais je ne vais pas me poser la question "oui, non, peut-être
Je fonce et je teste
La différence de prix avec une Vplus doit valoir le coup.
J'ai une Vplus neuve, j'aurais une Hyperion neuve dans un mois. Les deux passeront la saison estivale ensembles
Je fais confiance en la marque.
- RolluS
Ont attends les résultats avec impatience
Bientôt la pile a combustible? Ou la centrale nucléaire embarqué?
Je veux dire, ca évolue tellement vite
C'est bon j'ai passé ma commande d'une 4S en 4000mhA
Et 3.06$ de fdp en air parcel
Commande total 106$
Commande total 106$
Si seulement je pouvais la recevoir d'ici 10 ou 12jours... ca serait cool
Mais bon, j'ai pris une 25C.... c'est pas la VX à 35C
je me suis prit une cx3 en 3s 2100mah pour mon drag , je vous donnerai mon feedback en sachant que pour comparé sur mon drag j'ai des flypower evo 25 1800mah et que je charge via un imax B6 - je pourrais rechargé via un booster sur le terrain avec ces lipos?
Le booster n'est ni plus ni moins qu'une batterie.Mr Pomme @ 21 Apr 2009, à 14:01 a écrit : je me suis prit une cx3 en 3s 2100mah pour mon drag , je vous donnerai mon feedback en sachant que pour comparé sur mon drag j'ai des flypower evo 25 1800mah et que je charge via un imax B6 - je pourrais rechargé via un booster sur le terrain avec ces lipos?
PAr contre ton B6 et ses 50W tu vas être limité !
EDIT :
Au mieux du 2C en fin de charge ! On est loin du 5C
Tu ne tireras pas cet avantage.
En début :
P= 2.1 x 3.7 x 3 = 23w
Donc 2C = 46w possible
En fin de charge :
P= 2.1 x 4.2 x 3 = 26.46
Donc moins de 2C.
Bah je vais voir ce qu'elle donne celle là..... si c'est bien.... bah je prendrai la 35C à 133$Oli @ 21 Apr 2009, à 13:01 a écrit : @Gégé:
AhToi qui cherche la patate, pour une lipo à garder longtemps fallait taper dans le lourd !
Vu les fdp.... on peu se permettre de les commander 1 par 1
bha j'irai deja deux fois plus vite sans abimé l'accu et je pourrais revoler tout de suite après non?Oli @ 21 Apr 2009, à 13:03 a écrit :Le booster n'est ni plus ni moins qu'une batterie.Mr Pomme @ 21 Apr 2009, à 14:01 a écrit : je me suis prit une cx3 en 3s 2100mah pour mon drag , je vous donnerai mon feedback en sachant que pour comparé sur mon drag j'ai des flypower evo 25 1800mah et que je charge via un imax B6 - je pourrais rechargé via un booster sur le terrain avec ces lipos?
EDIT :
En début :
En fin de charge :
Donc moins de 2C.
et si ça marche vriament bien je revenderai mon imax pour m'acheter un hyperion si je m'en achete plusieurs
Je deverait donc charger à 4.2A en mode lipo balance sur mon imax b6?
Il y a un interet de prendre un booster plutot qu'une batterie de plomb hormis que dans le booster le chargeur 220V est incorporé?
Y a aussi une différence de qualité et de capacité de l'accu..
LoVe ChOcO
LoVe ChOcO
- Spektrum DX7, Mode 2.
Team Nuclear BigCP
Suisse (Neuch)
Team Nuclear BigCP
Suisse (Neuch)
- Angels.arael
- Lipo gonflant
ses nouvelles lipos on besoin du 0720i.net de toute façon le seul a envoyer 20A ^^
pour l'instant je garde mes A123 mais des que les pack 6s 2600mah sont dispo j'en prend 2 pour tester sur le 500 et le 600
Pour moi, la recharge ne se fera pas sous 1C de toute facon.... mon ImaxB6 ne veut pas aller au dessus de 3,5A en mode balance <_< .... Mais bon... faudra que je pense à changer de chargeur du coup
Au fait... onles trouve au US aussi : http://www.allerc.com/index.php?cPath=3_4_93" onclick="window.open(this.href);return false;
mmm elles sont même bien moins cher mais en back order... faut voir avec les fdp.
C'ets trop tard pour moi de toute façon
J'ai vu celle-là. Cool pour le 250.. Peut-être que je vais tester..
Parcontre, 21.25A (25C) et 38.25A (45C) pour les Hyperion G3.
La lipo Vplus, 29.4A (30C) et 49A (50C). Le poids, 3g de mieux pour la G3 mais 13.2% de capacité en moins...
La durée de charge est bien de 10-15 min, non? Parce que, acheter 4 G3 et charger deux en deux. Ce qui fait que ça vole presque non-stop..
Cerise sur le gâteau, même prix que les Vplus..
LoVe ChOcO
LoVe ChOcO
Team Nuclear BigCP
Suisse (Neuch)
Team Nuclear BigCP
Suisse (Neuch)
- LongChair
- Bonjour ?? :-)
Aucun probleme Gégé. Chez aircraft 10 jours c'est le max. la plupart du temps ca arrive une semaine apres. Les fdp sont généralement ridicules.GégéPilote @ 21 Apr 2009, à 12:27 a écrit : Si seulement je pouvais la recevoir d'ici 10 ou 12jours... ca serait cool![]()
Mais bon, j'ai pris une 25C.... c'est pas la VX à 35C![]()
Le contact avec eux est hyper facile et pour avoir discutté avec eux une fois par mail, ils m'expliquaient qu'ils "sponsorisaient" les frais de port afin d'etre compétitif (vu qu'ils sont au japon).
Bref, ca fait 4 ans que je commande chez eux et c'est tres sérieux
Leur site est une peu mal organisé pour pas dire "bor... lique" par contre
Bah je pense que je ferai un topo iciBoomslang @ 23 Apr 2009, à 19:53 a écrit : Je me laisserai bien tenter par ces batteries là moi...
Gégé tu essayes et tu nous tiens au courant ici ou "chez nous" tu sais !!![]()
Mais comme je l'ai dis, c'est une 25C. Je pourrai dire la difference avec une Vplus en 30C que je devrais recevoir dans tres tres peu de temps aussi
Pour mon cas où ma plsu grosse bebete est un 450 :Mr Pomme @ 21 Apr 2009, à 14:56 a écrit :Oli @ 21 Apr 2009, à 13:03 a écrit :
EDIT :
En début :
En fin de charge :
Donc moins de 2C.
Si je veux rechargé à 5C il me faut un chargeur capable de balancer 123W (max)et 10.5A ->l'hyperion mais si je me limite à 4C 105,84W et 8,4A
Mais avec tout ça je vais devoir me reprendre une nouvelle alim staibilisé lol.
Soit on se sent un peu tranquille avec un chargeur 20A pour pouvoir recharger peu etre plus tard à 9C
Mais des que je passe sur du 2600mah ,si je me prend un trex 500 par exemple je ne porurai plsu recharger à du 4C ...
Va falloir fair eun bon calcul mais je pense que je vais me prendre un hyperion en chargeur si vous me confirmé mes chiffres
3C pour quelle battery/chargeur?
Des 2600 ou des 2100?
Comme ces lipo G3 viennent de sortir.... je pense que l'on va trouver de plus en plus de chargeur capable de charger à 4C ces fameuse lipo.
Reste qu'à attendre
En tout cas, moi ma décision est prise concernant mon futur 600... ca sera un elec
Et avec, je changerai mon chargeur cette année aussi, mais pour ca je vais attendre, voir ce qui va sortir cette année
Reste qu'à attendre
- Angels.arael
- Lipo gonflant
avec le 0720i.net d hyperion on peux charger a 4C donc en 10-12 minutes a 10A que les 6s 2500mah
donc pour un 500 une lipo c'est bon pour un 600 il en faut 2 a mettre en parallèle
mais aucun chargeur n'est capable de charger des 6s 5000mah a 4C d'un coup encore
et pour l'hyperion ce hgenre d'alim serait ok?
cgi.befr.ebay.be/13-8V-350W-25A-Swi...%3A1|240%3A1318
Pourquoi avec l'hyperion on n'arriverait pas à charger à 5C?
- Angels.arael
- Lipo gonflant
parce que il faut parler en puissance
une lipo 6s 5000mah a 25.2V en fin de charge a 25A 5C ça fait 630W l'hyperion 0720i peux charger que 250W en reseau il peux 2*250W soit 500W mais faut 'couper' la lipo en 2
le max en 6s a 250W c'est 250/25.2=9.9A
donc une lipo que l'on charge a 10A pour 4C c'est 2.5A donc 2500mah en 6s
Que veux tu dire ? 2 packs ? 2 packs lipo ? ou 2 600ESPOli @ 26 Apr 2009, à 11:16 a écrit : AhahAttends de rencontrer plein de nitro dans un mois pour te faire une idée
Me concernant, fort possible que mon prochain soit aussi un 600ESP. Mais deux pack, 500$![]()
A ce sujet, je pense que je resterai sur des 25C pour les 4S du 3DX.
Par contre pour le 600, je prendrai des VX en 6S.
Car avec le 3DX, vu le prix de cette machine, je ne vais pas trop lui mettre le haut de gamme en lipo
