MSH u brain
derailleur
MSH u brain
Message par derailleur » 09 févr. 2015, 10:58
Un brain pour micro hélicos serait sur le point de sortir.
http://www.helifreak.com/showthread.php?t=680776
Si quelqu'un a des news....marcel, as tu eu connaissance de cette nouveauté ?? Sur ce post ça parle de précommande dans une semaine....ça doit donc être déjà bien abouti.
M1
my____
Re: MSH u brain
Message par my____ » 09 févr. 2015, 11:04
patchy m'a fait découvrir ca hier :) ... c'est une bonne nouvelle.
vidéo du post Helifreak :
https://www.youtube.com/watch?v=8ni7hnIk_Zo[/video]
j'ai l'impression que OnTheSnap d' Helifreak est le nouveau développeur ?
Message en Anglais d'OntheSnap :
A great deal of time has been spent on tuning the uBrain on the 180. So when you get it, you simply select the 180 defaults and it flies fantastic out of the box Then you pick your flight style preference (beginner up to hard 3d), and go fly. You don't need to get into the advanced tuning if you don't want to.
There are a lot of advantages to running a uBrain over the stock such as:
-Any RX support
-Self leveling/Rescue
-Optional Bluetooth module with Android App
-3 flight banks. Great for trying new settings, optimizing for diff headspeeds, etc.
-Pitch Pump. Really helps with micro collective authority making tic tocs much easier, and pop and lock a lot more fun
-Ability to save and share config files with other pilots
-Built in flight counter
-Full PC interface for configuration.
-Support for custom cyclic servos like the blue arrow that require reversing
-Support for higher end tail servos
-Superior vibration immunity based on hardware filter technology. Very high tolerance to models that are not so perfect (many crashes on mine with extra vibes but still flies great)
-Incredible piro consistency through high speed maneuvers. Piro comp
-Fully tunable tail including tail precomp, stops etc. the improvement on the tail is profound
-Easy servo position trimming for the cyclic and tail.
-Much greater ability to tune and optimize for different blade choices
-Big firmware improvements over time. A lot of Brain features coming that work with the uBrain and full size.
Just a few highlights above off the top of my head that made a big difference for me.
Corrado annonce des pré-commandes rapidement avec une disponibilité vers le 10 Mars.
A 100€ le module
wait & see :)
Otatiaro
Re: MSH u brain
Message par Otatiaro » 09 févr. 2015, 11:09
De ce que je vois sur les photos, c'est un BRAIN avec des connecteurs adaptés au 180CFX, ni plus ni moins.
Thomas.
PS : Alex n'est pas développeur (pas au sens informatique, il aide au développement du produit, mais ne touche ni au code ni au hardware, il pilote et donne ses idées).
Support : contact@eznov.com
my____
Re: MSH u brain
Message par my____ » 09 févr. 2015, 11:16
Merci Thomas pour les infos :)
derailleur
Re: MSH u brain
Message par derailleur » 09 févr. 2015, 11:40
difficile de voir qui fait quoi mais le GY280, copie du Vbar a permis de passer le 130X en 3S, de mettre n'importe quel servo rotatif ( sur le 130X il en faut 1 "inversed", sur le 180CFX ils sont tous inversed, ce qui rend impossible le remplacement par des servos lambda) et d'avoir tous les réglages comme les "gros"...Alors si un constructeur FBL sort un truc officiel, "plug and play" et qui marche ça devient très très interessant. Sur le GY280 il faut modifier les prises de servos...et ça reste une "chinoiserie"....
M1
my____
Re: MSH u brain
Message par my____ » 09 févr. 2015, 19:06
Le Docteur
Re: MSH u brain
Message par Le Docteur » 09 févr. 2015, 20:13
C'est tout mignon je trouve :)
Bien Amicalement,
KoRn_BeeF
Re: MSH u brain
Message par KoRn_BeeF » 09 févr. 2015, 20:23
par contre c'est tres con de ne pas avoir laissé les channels 4/5/6 avec prise standard je trouve
Multi-rotor : GEP210
Avion : EXTRA 330SC 1.85m
Mon Thingiverse
chris9200
Re: MSH u brain
Message par chris9200 » 09 févr. 2015, 21:24
KoRn_BeeF a écrit :par contre c'est tres con de ne pas avoir laissé les channels 4/5/6 avec prise standard je trouve
On c'est pas encore les câbles qui seront fourni, il y aura sûrement le cable pour recepteur standard.
KoRn_BeeF
Re: Re : MSH u brain
Message par KoRn_BeeF » 09 févr. 2015, 21:29
C'était pour msh que je disais ça pour standardiser les câbles
Mon Thingiverse
derailleur
Re: MSH u brain
Message par derailleur » 09 févr. 2015, 22:10
c'est pas mal du tout, je trouve. Ils arrivent sur un marché à prendre. Avec les 180CFX ça va se vendre comme des petits pains
M1
KoRn_BeeF
Message par KoRn_BeeF » 09 févr. 2015, 22:11
Faut voir le prix
Mais si c'est un brain il sera au prix d'un brain
Mon Thingiverse
my____
Re: MSH u brain
Message par my____ » 09 févr. 2015, 22:14
C est 100€ annoncé
MaYeuT
Re: MSH u brain
Message par MaYeuT » 09 févr. 2015, 22:49
Tiens, un brain a moitié prix :ph34r:
Marne (51) - 35 ans
Graupner MZ24
Hyperion Duo+
RF 7.5 & Next
Lynx Team Pilot
derailleur
Re: MSH u brain
Message par derailleur » 10 févr. 2015, 08:17
100 € ça vaut le coup. En mettant 3 servos bluearrow avec pinions métal à 6 dollars sur Hk tu gagnes déjà 30 €sur le set d'origine. Si en plus tu peux régler les gains en Bluetooth c'est vraiment top. Peuvent pas les vendre au prix du brain, c'est quasi le prix d'un 180 Cf. A 100 € c'est un peu plus cher que le module d'origine avec plein de possibilités de réglages sans être bridé par le choix des servos.
M1
my____
Re: MSH u brain
Message par my____ » 11 févr. 2015, 14:41
Pré-commande possible sur Fast Lad
http://www.fast-lad.co.uk/store/product ... s_id=31789
Par contre j'avais lu cela hier soir mais ce sera 120€
derailleur
Re: MSH u brain
Message par derailleur » 11 févr. 2015, 15:18
On doit les trouver à moins cher...En achetant ailleurs que fast lad qui ne sont jamais bien placés niveau prix et frais de port
M1
my____
Re: MSH u brain
Message par my____ » 11 févr. 2015, 15:27
Sur helifreak il parle de 120€/120€ en prix officiel
Guillaume.R
Re: MSH u brain
Message par Guillaume.R » 11 févr. 2015, 18:27
Pour ceux qui ont Facebook il y une video de presentation du module et une autre qui montre la configuration de celui ci, sur la page de MSH :
https://www.facebook.com/msheli.srl?fref=ts
markassdecestas
Re: MSH u brain
Message par markassdecestas » 11 févr. 2015, 21:46
désolé mais je ne connais rien au brain ^_^
il va falloir lui coller un sat en plus surement non?
j'ai eu:
chris9200
Re: MSH u brain
Message par chris9200 » 11 févr. 2015, 21:57
markassdecestas a écrit :désolé mais je ne connais rien au brain ^_^
Sat ou récepteur
lolo63
Re: MSH u brain
Message par lolo63 » 11 févr. 2015, 22:20
derailleur, tu l'as mis ou le gyro sur ton 130X? dans le chassis devant? a la place de celui d'origine?
padawan de steph66
Image DX1Ot monomanche
Image Next
Image :
Nano CPX;Trex150
Goblin 700 => neuron
Oxy3 qube =>beastX
markassdecestas
Re: MSH u brain
Message par markassdecestas » 11 févr. 2015, 22:22
dans ce cas la,le sat sera le plus simple niveau cablage.
il faut que je regarde si c'esp pas trop galere a regler le brain.
j'ai plus l'habitude des 3gx,zyx et beastx
j'ai eu:
derailleur
Re: MSH u brain
Message par derailleur » 11 févr. 2015, 22:56
lolo63 a écrit :derailleur, tu l'as mis ou le gyro sur ton 130X? dans le chassis devant? a la place de celui d'origine?
sur le 130X, à la place du 3 en 1
M1
lolo63
Re: MSH u brain
Message par lolo63 » 11 févr. 2015, 23:13
Merci. Je me tenterais peut-être la modif sur le 130. Avec le châssis et la partie AC complète Lynx ca pourrait faire un truc sympa.
padawan de steph66
Image Next
Image :
Nano CPX;Trex150
Oxy3 qube =>beastX
derailleur
Re: MSH u brain
Message par derailleur » 12 févr. 2015, 08:38
Appelle moi si tu veux des billes
M1
lolo63
Re: MSH u brain
Message par lolo63 » 12 févr. 2015, 11:15
Oui j'y ai pensé ;)
padawan de steph66
Image Next
Image :
Nano CPX;Trex150
Oxy3 qube =>beastX
live-o-matic
Re: MSH u brain
Message par live-o-matic » 01 mars 2015, 00:09
tout le monde parle du blade180
mais ça ira pour un mini protos avec 1sat ?
- mini protos
- protos
- logo 550sx
- logo 700 xxtrem
- dx7s
ducat'
Re: MSH u brain
Message par ducat' » 01 mars 2015, 00:29
live-o-matic a écrit :tout le monde parle du blade180
À priori oui si tu changes toutes les connectiques servo et cie...
Envoyé de mon iPad à l'aide de Tapatalk
having fun in fpv
__________________________Image_________________________
live-o-matic
Re: MSH u brain
Message par live-o-matic » 01 mars 2015, 13:25
merci ducat
j'avais pas vu c'etait les même connectique que sur les petits blade <_<
du coup autant attendre de trouver une bonne occas
- mini protos
- protos
- logo 550sx
- logo 700 xxtrem
- dx7s
