Mikado logo 690 sx
- renaud67
Mikado logo 690 sx
En trainant sur les forums Allemand je suis tombé sur ça.
Pas mal de modif.
Dans les grandes lignes:
Courroie , boitier Ac et poulie renforcées .
Kv moteur rabaissée a 370 KV pour permettre l'utilisation d'un pignon plus gros pour avoir plus de contact avec la couronne .
Swash plate plus costaud
Pied de pale avec trou en 5 mm .. Donc plus besoin d'entretoise pour la vis qui tient les pales ..
Il y aurait un rack a lipo.
train rehaussée qui permet d'avoir une bulle plus grosse et donc avoir une meilleure proportion de l'ensemble et une meilleure visibilité ..
Bague qui vient coiffée le palier supérieur plus grosse..
Poids RTF en 12s et 5A environ 4800 grammes.
Mikado has yet to offer (and many have asked for it), a "690" heli (like other "700's" that are really 700 "lites", using 690's vs. 700's or even 713's like the Logo 700), that is super light, yet can handle full blown "700 class head speeds". The 600SE of course does 690's, but has it's limits.
So, enter the Mikado Logo "690SX". It uses the Logo 600 molded frame set as a base, but adds the tougher SX drive train on 12S with a new from Scorpion custom made for the heli 370kv 4525 motor, which (due to the low kv) uses a large pinion to keep the drive train good and tough. Even with the excess of power, gear strips are not an issue...Kyle has proven that, as he's been prototyping and flying the crap out of one for some time now.
It uses a new belt type/design and new rear gearbox parts and pulley design to make the tail able to handle extreme abuse without "belt issues", with a redesigned composite carbon/metal front tail drive pulley and larger one-way to handle the power, beefier tail boom supports, coupled with the new SX head and it's better dampening, larger beefier swash plate, an integrated to the frame front battery support so no plates are needed to mount the two 6S packs in the frames, a new bottom extension for the frame/landing gear situation, (the heli as it sits on the ground is taller than the Logo 600 series), and a larger canopy that gives it more "presence" and a proper proportion for the longer boom while in the air...the Logo 600SE always looks too "long for the canopy size". The canopy still looks like a Logo 600, but it is larger.
Kyle's prototype all-up weight RTF with 12S 5000's comes in at only 10.5-10.75 lbs., depending on servos used, BEC vs. 2S etc. The thing is an animal, and due to it being so light, 2000 head speed is all Kyle uses...but man is it REALLY quick. You could use 4500mah packs, still get good time, and it's even lighter!! You just can't bog it down with the 4525 motor in it, and with the new designs installed, it's not fragile either. Kyle has been abusing one for awhile now and it's handled the abuse well...the whole point of the heli...which is a super hot lightweight "690" that you can smack to your heart's desire.
Pas mal de modif.
- Le Docteur
Re: Mikado logo 690 sx
Je venais de le voir et j'avais envie de faire un post rien que pour toi
Tu ferai mieux d'aller voler par ce temps, Lucky Luke va
http://helidaily.com/first-pictures-the-new-logo-690sx/
Bien Amicalement,
- Medivh
Vu sur FB aussi.
Très chouette et vu le poids ya moyen de voler 5 minute en 3D.
Manque plus qu'ls nous sortent un logo 350 SX (format 450) en 4S ou 6S et ce serait top.
Ma tribu:
- renaud67
Le docteur :
je peux pas voler c'est Dimanche .. Pas le droit de faire de bruit ..
Dommage car il fait 15 degrés et ciel bleu..
Bon ben au moins on est fixé pour mikado ..
On s'attendait a un nouveau xxtreme et on finit avec un sx..
Modifié en dernier par renaud67 le 09 mars 2014, 14:39, modifié 1 fois.
- protm
- Caliméro
Mikado logo 690 sx
Tant mieux! Au moins ce Logo 600 a encore quelques jours devant lui!
Par contre fini la courroie Kevlar sur celui là aussi!
Et ils ont mis un roulement de galet d'ac bien large, ça évitera les saut de courroie comme le 550SX.
Édit: un gros 4525 en plus! Ça devrait envoyer
Envoyé via Tapatalk
Envoyé via Tapatalk
-Porket 240 Racer
-FatShark Attitude SD V2
-Multiplex Funjet Ultra 4S
-Ma chaîne Youtube
-Porket 240 Racer
-Ma chaîne Youtube
- ducat'
ah cool Renaud que tu sois là!
apres plus ample inspection, tu penses toujours que c'est rechauffé pas terrible?
- renaud67
Merci Duca .. je me suis dit que c'est comme en politique on peut pas plaire a tous le monde du coup je vais faire avec.. J'aime trop ce forum
Ben en fait ils ont quand même modifier pas mal de truc maintenant que les infos tombent..
Apres la seule chose que je reproche a ce type de châssis c'est la vulnérabilité de la lipo qui dépasse sur son nez et les dégâts en plus causé par le chassis qui généralement explose a l'impact ..
Plus long a réparer ..
Si on crashe pas c'est top
La position des sangles velcro super galère a scratché... car quasi pas de place sur la partie haute..
J'aurai préféré un grand frère au logo 480 avec un format inférieur au 700 xxtreme.. car la ça donne effectivement un air de réchauffée ce qui n’enlèvera rien a sa faculté de super bien voler ..
- protm
- Caliméro
Tu remarquera que le châssis a été renforcé par la pièce en bas de châssis. L'endroit ou ça père a l'avant a été renforcé donc ça sera mieux
Envoyé via Tapatalk
Envoyé via Tapatalk
-Porket 240 Racer
-Ma chaîne Youtube
-Porket 240 Racer
-Ma chaîne Youtube
- Davy
Je suis pas convaincu par ces renforts. A l'endroit des deux vis le chassis fait 1mm d'épaisseur, je suis pas certain que ça serve à grand chose.
Ils sont quand même fort pour toujours réutiliser les même moules. Je sais que ça coute extrêmement cher, mais là l'assemblage d'un ancien châssis avec des nouveaux "morceaux" comme ça ça ne me plait pas énormément...
Planeurs : MPX Heron
- protm
- Caliméro
Ouais c'est bizarre c'est vrai! Le moule doit leur plaire
Pour les renforts je sais pas. Speedix fait une option similaires deux plaques de carbones exactement comme là. Mais est-ce que c'est efficace je sais pas.
Envoyé via Tapatalk
Envoyé via Tapatalk
-Porket 240 Racer
-Ma chaîne Youtube
-Porket 240 Racer
-Ma chaîne Youtube
- Davy
Je suis vraiment sceptique sur les renforts.
C'est marrant le contro Scorpion ? Kontronik, YGE, Scorpion... ?
Ils n'auraient pas de contrats avec eux et seraient libres de mettre ce qu'ils veulent ?
- protm
- Caliméro
Je sais pas si il sera livré avec un Scorpion si?
Ils ont des contrats avec les trois je pense
Scorpion pour les moteurs et YGE/Kontronik pour les ESC
Envoyé via Tapatalk
Envoyé via Tapatalk
-Porket 240 Racer
-Ma chaîne Youtube
-Porket 240 Racer
-Ma chaîne Youtube
- antono34
J'ai eu :
- renaud67
Merci Nico pour la vidéo
Il y a pas a dire c'est d'une fluidité
- Davy
Mais à quoi sert le 700 XXTreme ?!
- renaud67
Ben il est quand même plus imposant le xtreme..
Curieux de savoir si le tarif de celui ci , sera a 100 euro prêt le même que le 600 SE...
J’espère que non sinon je suis capable d'en reprendre un
- protm
- Caliméro
La vache! Un vol comme ça du Xxtrem j'aurais trouvé ça cool, mais venant d'un Logo 600 "tunning"
Bizarre comme choix en tout cas! Mais il envoie sec!
-Porket 240 Racer
-Ma chaîne Youtube
-Porket 240 Racer
-Ma chaîne Youtube
Moi j'aime, reste à voir le tarif.
- renaud67
Vue que 90 % vient du 600 SE-SX avec un peu de bol il y aura 100 euro de plus maxi ..Nicolas3881 a écrit :Moi j'aime, reste à voir le tarif.
Bien qu'avec eux on sait jamais
- BlackBear
On sait déjà à quoi s'attendre avec Mikado... Ca va piquer sec. Mais au moins ils proposent un 700 sans le chassi carbone de l'Extreme. Ca manquait dans la gamme. Ca va être un 700 vraiment léger...
Avion: Plein de trucs
Télécommande Spektrum DX9
- Le Docteur
Bien Amicalement,
- BlackBear
A, mince j'avais pas vu ce post, j'en ai créé un dans la section supérieur car c'est une classe 700 pas un 600...
- renaud67
- BlackBear
Specs et tarifs: http://shop.mikado-heli.de/LOGO-Helicop ... 571&p=7571
On s'en sort au même prix qu'un super combo Align pour une fois si on rajoute servos et ESC...
