La DX9 pour septembre...
Re: La DX9 pour septembre...
Nouveau Spektrum AirWare Software pour la DX9 version 1.07 !
New Features & ImprovementsAdded ability of all radios to share model configuration (SPM) files with the new DX7.Added new screens to support Sound Categories. These allow you to select sounds more easily by grouping them into user-editable lists (categories) to reduce scrolling needed to find the sound you want. The radio supports up to 16 categories; this update will create default categories but you can modify or remove them as you desire.The pre-flight checklist shows the name of the model on power-up. This allows you to verify the right model is being started without having to go through the complete list first.New trainer mode “FPV” added to allow head tracker inputs to be mapped to any channel, with adjustable scaling and reversing. This mode enables easy mapping of head tracker channels to receiver ports, while not affecting flight controls. It supports both wired and wireless head trackers.Add support for Flight Pack Capacity (mAh) and Receiver Pack Capacity (mAh) sensors.Add support for ESC sensor.X-Plus channels are now able to be configured to generate warnings in 18- channel systems, in addition to the normal channels previously available.On the Model Copy utility, you are now able to select the Source model for copying. It is no longer necessary to use Model Select first.When setting up a timer in a speaking radio, a 20-second alert is now available.You can now use the “wiggle” function to select analog inputs when entering a “switch” option. Just move the appropriate switch or stick or slider and it will select it automatically.Trainer input is now more tolerant of inputs from devices such as head trackers (DX6, DX7, DX9 only).CorrectionsAS3X Gains telemetry screen does not show when configured to not show.Custom Voice Events of 16 steps now advance properly.Sailplane AIL>RUD mix field “Sub Switch” is now exported properly.Heli gyro trim values are aligned properly for all flight modes.Heli trim setup screen operates properly in tray radios.Digital Switch Setup does not allow selection of Flight Mode switch if the Flight Mode system is not configured.Vario volume is now exported and imported properly.Trainer inputs are not allowed to exceed Absolute Travel settings.Corrected delay between tx voltage status announcements.Telemetry screens now refer to Turbine rather than JetCat.Telemetry screens with trim displays now properly indicate centered status the same as the main screen.Sequencers and Gyros will now properly release a channel when being turned off. Note that you must completely disable the gyro for the old channel name and function to be fully restored. That is, you must set the Gain input (first screen) to INH, click NEXT, then set the mix to INH > INH, then the switch to INH. Only then will the channel be completely and properly freed up. For sequencers you only need to set the output channel to INH.“Tone” selection for inactivity alarm now operates properly (speech radios only).Audio System Changes (DX6/DX7/DX9/DX18T/DX18G2 only)Added support for more audio file types.Thousands is spoken correctly in English.When setting up custom sound events, the active switch position for steps and reset on sequenced events is utilized properly.New sounds have been added to the list.Spanish speech has consistent volume level.
Vivement que j y passe ![Dan.San :P](./images/smilies/10.gif)
Moi je la passe ce soir ! ![Dan.San :)](./images/smilies/1.gif)
- fabu74
Je vais peut être m'y coller aussi vu le temps magnifique aujourd'hui.
- Le Docteur
lol les gars, godjc l'avais déjà annoncé au début du mois.
Bref, j'ai presque un mois d'avance sur vous![:p :p](./images/smilies/tongue.gif)
Bien Amicalement,
![Image](https://img15.hostingpics.net/pics/789521SignatureH4.jpg)
C'est facile avec une machine à voyager dans le temps...
Modifié en dernier par Nicolas3881 le 21 févr. 2015, 23:20, modifié 1 fois.
- Le Docteur
Mon tardis n a rien a voir dans l'histoire sinon je m en servirai plutôt pour piloter, améliorer mon pilotage, casser et récupérer la machine intacteNicolas3881 a écrit :C'est facile avec une à chine à voyager dans le temps...
Bien Amicalement,
J'ai une lipo turnigy 4000 dans ma DX9. Elle était sur ma DX8 avant. Elle tient de moins en moins la charge..Je dois la charger assez souvent. ça vous le fait ? à changer je prendrais plutôt la spektrum même si l'écart de prix est conséquent.
Vous avez un peu des retours ?
JR Forza 450 ex,spirit
OXY 4 6S spirit
MINICOMET spirit
radio DX9
VTT Kona process 111 DL......
OXY 4 6S spirit
MINICOMET spirit
radio DX9
- Le Docteur
Salut ! Moi j'ai la Spektrum et je la charge assez régulièrement.
J'ai l'impression que la DX9 consomme plus.
Bien Amicalement,
Oui la dx9 semble consommer. Même avec la lipo spektrum l'autonomie est juste correcte.
- Sebcbien40
J'ai également dans ma DX8 la lipo TURNIGY 4000mAh. Je la charge avec le chargeur secteur Spektrum. Je tiens un bon bout de temps avec. J'ai mit l'alarme de tension à 7,2V. Ça fait 2 ans que je l'ai. Je ne sais pas depuis combien de temps tu l'as... Mais la lipo Spektrum coûte un rein pour la même utilisation...
Sinon il faut voir du côté de chez Marcel si la lipo Gensace 3500mAh passe dans ta DX9
http://www.helidigital.com/shop/lipo-ge ... rx-2s.html
EDIT: je viens de regarder sur le PC et ce n'est seulement qu'une batterie de réception avec une prise servo...
Donc perso je repartirai sur une TURNIGY!![Dan.San ;)](./images/smilies/6.gif)
@ plus![Dan.San ;)](./images/smilies/6.gif)
Seb
@ plus
Seb
![Image](http://monsant.fr/Partage/Heli4/SIGNATURE69-goblin.gif)
Pour un hélico de taille 500-500, vous me conseillez quoi comme rx ? merci.
Quel module pour faire quoi ?
pour un beastx v3. Pour voler.
Je dirais un ar6--- ou ar7--- avec sat...
Pour le prix d un sat, au dessus de 450, je ne prends pas de risque. Outre la voie supplémentaire les ar7--- offrent je crois un "rail" d alim plus adapté aux puissances un peu plus conséquentes![Dan.San ;)](./images/smilies/6.gif)
Merci !
C est pour le 480 ou le 380 ?Nicolas3881 a écrit :Merci !
Sinon vu que ca parle batterie dx9, vous tenez combien de temps à la louche avec la batterie fournie d origine ?
Bon ça doit être normal. Je vais baisser la tension d'alerte à 7,2 V alors, elle est à7,4 V pour l'instant. Je vais voir et rien changer pour l'instant. Mais faut vraiment que je la charge régulièrement et plus souvent qu'avant. Clara doit avoir une trop grande gueuleLe Docteur a écrit :Salut ! Moi j'ai la Spektrum et je la charge assez régulièrement.
OXY 4 6S spirit
MINICOMET spirit
radio DX9
OXY 4 6S spirit
MINICOMET spirit
radio DX9
- Le Docteur
Je l'ai laissé à 7.4V mais la question que je me pose c'est si on peut pas aller plus bas car finalement c'est juste une lipo sur une TX et que ça craint moins que sur nos machines.
Bien Amicalement,
- Choubipay
Je confirme que la dx9 tient beaucoup moins longtemps que la DX8 ![Dan.San :(](./images/smilies/24.gif)
Je la recharge 1x/semaine (je dois m'en servir 5-6h) alors que la dx8 c'était plutôt 1x/mois - pour facile 15-20h
On peut aussi calculer le temps d'utilisation - ya un menu pour ca![Dan.San ;)](./images/smilies/6.gif)
Tant que ça vole...
Tant que ça vole...
![Image](http://img694.imageshack.us/img694/3228/49646copie.png)
Ah oui ca fait quand meme 3/4 fois plusChoubipay a écrit :Je confirme que la dx9 tient beaucoup moins longtemps que la DX8
Tant que ça vole...
Merci pour ce retour precis
Du coup ca vaut le coup d avoir une nimh ou une lipo en spare au cas ou dans la caisse !
- Sebcbien40
Sacrée Clara!!!!! Elle en pompe...Choubipay a écrit :Je confirme que la dx9 tient beaucoup moins longtemps que la DX8
Tant que ça vole...
De l'énergie!!!!!!
Hey!!!!!! What did you expect????
She wants just Schweppes...
Tapatalk par Ipad
- Pat5983
Même constat entre la 8 et la 9, je pense aussi me prendre une Lipo 4000 du coup...
Gaui X3 6S + Spirit
Gaui X4 II + Spirit
Protos + Spirit
DX9
Gaui X4 II + Spirit
Protos + Spirit
DX9
- Choubipay
Mdr Seb ! ![:lol: :lol:](./images/smilies/laugh.gif)
Tant que ça vole...
Tant que ça vole...
En fait avec la lipo spektrum je trouve l'autonomie correcte même si l'on ne bat pas des records. C'est surtout le temps de recharge avec le chargeur anémique fourni qui est long.. mais long...
- Pat5983
SOS aux balaize de la programmation...
Est ce que l'un de vous pourrait jeter un oeil là dessus :
viewtopic.php?f=122&t=61282
Merci par avance
Merci par avance
Gaui X3 6S + Spirit
Gaui X4 II + Spirit
Protos + Spirit
DX9
Gaui X4 II + Spirit
Protos + Spirit
DX9
- lionel70
Petite question concernant la télémétrie : dans le menu "Paramètre Fichier" à quoi servent les fonctions "Unique : Oui/non" et "Permettre : Oui/non". Ce dernier me semble être l'autorisation d'écrire sur la carte SD car il apparait un "Enabled" dans le manuel... mais quid de "Unique" ?
- godjc
Ca configure l'arrêt de l'enregistrement. Il débute avec la commande programmée et s'arrête avec unique sur non ou se poursuit jusqu'à déconnection avec le paramètre oui.
Jc
Jc
Frsky X20S
Frsky X20S
- lionel70
Merci, c'est bien dans la logique de la télécommande en fait.![Dan.San :)](./images/smilies/1.gif)
Je pense avoir un petit souci. Quand mon manche de pas est au milieu j'ai 21% sur le monitoring. Faut que je descende d'un cran vers le bas pour avoir 0.. Faut pas encore la renvoyer la ? C'est l'explication de mes réglages bizarres pour être à 0 au neutre.. Commence à me saouler spektrum, elle était partie en sav pour autre chose et avait théoriquement été contrôlée.
OXY 4 6S spirit
MINICOMET spirit
radio DX9
OXY 4 6S spirit
MINICOMET spirit
radio DX9
- Guilou
Tu dois surement pouvoir refaire une calibration non ?
![Image](http://kkwait.free.fr/tux.png)
- godjc
Pour savoir place toi sur un modèle avion. Dans le moniteur, manche au milieu, tu dois avoir 0 partout.
Déplacer les manches et les remettre à 0 doit donner 0 ou très proche. Enfin déplacer chaque manche dans un direction après l'autre, les autres valeurs doivent rester fixes.
Dans un autre mode, entre les mixages et les courbes, il n'est pas toujours évident de tester.
Jc
Jc
Frsky X20S
Frsky X20S
- BlackBear
Un recalibrage pour être sûr...
Avion: Plein de trucs
Télécommande Spektrum DX9
ben ptain...j'ai recalibré et c'est bon
c'est drole car je pensais être à jour de ça...Merci les gars
du coup je reprends les réglages de mes machines. ![:unsure: :unsure:](./images/smilies/unsure.gif)
OXY 4 6S spirit
MINICOMET spirit
radio DX9
OXY 4 6S spirit
MINICOMET spirit
radio DX9
- godjc
As tu déjà recalibré depuis que tu l'as reçu ? Je vérifie, comme je te l'ai expliqué, à après chaque flash.
Cdt
Jc
Cdt
Jc
Frsky X20S
Frsky X20S
- BlackBear
Surtout si revenu du SAV. S'ils ont touché aux potentiomètres, leur position a pu changer...
Idem après une modification de firmware...
Si ça apparait de nouveau, vérifie les potentiomètres s'ils ne bougent pas...
Merci les gars, je me rappelle plus depuis quand j'ai fait cette manip. On m'y reprendra pas à deux fois. Je me voyais pas à nouveau affronter le SAV HH, ça aurait été pour moi l'arrêt de mort de la DX9 pour changer de marque
pour régler l'oxy on était étonné avec fabu74 de la gueule de la courbe de pas pour avoir le 0 au neutre. Bas voilà ![:rolleyes: :rolleyes:](./images/smilies/rolleyes.gif)
OXY 4 6S spirit
MINICOMET spirit
radio DX9
OXY 4 6S spirit
MINICOMET spirit
radio DX9
J'ai envie d'enlever les cales sur le manche de pas pour essayer. Sûrement plus de finesse dans la gestion du pas avec plus de course. Je compte tout recalibrer après. Ma question (je pense avoir la réponse mais je veux être sur) ; est ce que l'augmentation physique de la course du manche de pas ne va pas modifier le réglage de mes hélicos et de mes contrôleurs (fin de course des castle) ?
OXY 4 6S spirit
MINICOMET spirit
radio DX9
OXY 4 6S spirit
MINICOMET spirit
radio DX9
- Pat5983
Je ne pense pas te dire une bêtise en te répondant que cela ne changera rien après recalibrage.
Pour le recepteur la course est la même, pour l'émetteur il y a juste plus de point pour "compter " une même courde, c'est donc la résolution qui augmente.
Gaui X3 6S + Spirit
Gaui X4 II + Spirit
Protos + Spirit
DX9
Gaui X4 II + Spirit
Protos + Spirit
DX9
- KoRn_BeeF
+1Pat5983 a écrit :Je ne pense pas te dire une bêtise en te répondant que cela ne changera rien après recalibrage.
Mais attention au ressenti aux manches qui risque de bien changer
Multi-rotor : GEP210
Avion : EXTRA 330SC 1.85m
Mon Thingiverse
Mon Thingiverse
