Turnigy 9XR Transmitter
blacline
Message par blacline » 25 déc. 2012, 21:02
The greatly anticipated Turnigy 9XR has arrived!
The software for the 9XR first began development 6 years ago. Since then it has been tweaked, tuned, changed, updated and revamped by members of the R/C community into a powerful - yet easy to use interface. Our engineers designed the physical product around the R/C communities software changes and input. The culmination of all these is the Turnigy 9XR!
For many users this will be the perfect 9 channel radio straight out of the box, but there are many tinkerers out there who love modifying and pushing the boundaries of what is possible from their radio. We have factory fitted the 9XR with an AVR ISP header to simplify the development of custom software, we have launched turnigy9xr.com as the epicentre for software developers and additional community support for all 9XR users......With the 9XR we encourage it!
The 9XR is supplied preloaded with top quality software which is full of features and yet remains easy to use. Our aim was to develop a radio for you, the hobbyist, with an extensive list of standard features usually expected from a radio system 3 times the price. Our Turnigy 9XR is everything you imagined and more!
9XR Standard Features:
• 8 Channel PPM/9 Channel PCM
• Full Ball Bearing gimbals
• Adjustable Stick Length
• Digital Trims on all Primary Axis
• 16 Model Memory
• Assignable Switches
• Freely Assignable Channel Mixes
• Graphical Dual Rate and Exponential
• Sub Trim and Travel Adjust
• Flaps and Differential
• Throttle Hold
• Supports Heli/ Aero/ Glider Model Types
• Programming Templates Based on Model Type
• Supports M1, M2, M3, M4 stick modes
• 128 x 64 backlit Liquid Crystal Display
• Built in JR & Futaba Trainer Ports
• PPM & PCM Output
• JR Form Factor RF Modules (Orx Dsm2, Orx Open LRS 433Mhz etc)
• Programmable Timers
• Low Voltage Warning and Buzzer
• Supports 3s Lipo (Required)
• 9XR Firmware Pre-loaded
• AVR ISP Interface
• Internal 2.4GHz Antenna
Online support and user forums available at: www.turnigy9xr.com
Spec:
Channnel: 8ch ppm/9ch pcm
Display: 128*64LCD (Backlit)
Support Type: Heli/Acro/Glid
Model Memory: 16
Stick modes: 1, 2, 3, 4
Encoder type: ppm/pcm
Module Interface: JR Compatible (See Related Items Below)
Simulator Interface: Yes (JR & Futaba)
Buzzer: Yes
Required:
Battery 3S Lipo
RF Module
Included:
Turnigy 9XR Transmitter (Mode 2 – Throttle on Left Stick)
Quick Start guide
Note: This version is supplied without an RF Module, Please order the relevent RF module from the accessories list below.
Perso je garde ma 9X je la trouve vaiment moche mais c mon avis, apres je trouve ca un peu moyen d'hk d'utiliser ER9X mais c'est open source donc bon.
On peu reprocher beaucoup de chose au chinois, mais eu au moin ils bouffent leurs chiens!
ImageTurnigy 9x er9x frsky version
Jordan83
Re: Turnigy 9XR Transmitter
Message par Jordan83 » 25 déc. 2012, 21:18
Je la trouve vraiment laide aussi mais le prix est intéressant.
http://www.hobbyking.com/hobbyking/stor ... dule_.html
Si ça fonctionne aussi bien que la 9X, c'est le succès assuré.
Yoy24
Message par Yoy24 » 25 déc. 2012, 21:23
Yop,
translate:
Le très attendu Turnigy 9XR est arrivé!
Le logiciel pour le développement 9XR a commencé il ya 6 ans. Depuis lors, il a été modifié, à l'écoute, changé, mis à jour et remanié par les membres de la communauté R / C en un puissant - et pourtant facile d'employer l'interface. Nos ingénieurs ont conçu le produit physique autour des changements de R / C de logiciels et les communautés d'entrée. Le point culminant de tout cela, c'est la 9XR Turnigy!
Pour de nombreux utilisateurs ce sera le parfait 9 canal radio tout droit sorti de la boîte, mais il ya des bricoleurs nombreux là-bas qui aiment modification et de repousser les limites de ce qui est possible à partir de leur radio. Nous avons monté en usine avec la 9XR un en-tête AVR ISP pour simplifier le développement de logiciels sur mesure, nous avons lancé turnigy9xr.com comme l'épicentre de développeurs de logiciels et de soutien communautaire supplémentaire pour tous les utilisateurs 9XR ...... Avec le 9XR nous encourageons il!
Le 9XR est fourni préchargé avec des logiciels de qualité supérieure qui est plein de fonctionnalités et pourtant reste facile à utiliser. Notre objectif était de développer une radio pour vous, les amateurs, avec une longue liste de caractéristiques de série habituellement attendu d'un système radio 3 fois le prix. Notre 9XR Turnigy est tout ce que vous imaginé et plus encore!
9XR Caractéristiques standard:
• 8 PPM Chaîne / 9 Channel PCM
• Toutes les cardans roulement à billes
• Longueur du bras réglable
• Trims numériques sur tous les produits Axis primaire
• 16 Mémoire de modèle
• Commutateurs assignables
• Canal librement assignables Mixes
• Taux graphique double et exponentielles
Garniture • Sub et de réglage du débattement
• Volets et différencié
Maintien des gaz •
• Prise en charge Types de modèle Heli / Aero / Planeur
• Modèles de programmation basé sur le type de modèle
• Prise en charge M1, M2, M3, M4 modes de pilotage
• 128 x 64 Affichage rétro-éclairé à cristaux liquides
• Construit dans les ports formateur JR & Futaba
• PPM et PCM Sortie
• Facteur de forme JR modules RF (Orx DSM2, Orx Ouvrir LRS 433Mhz etc)
• Minuteurs programmables
• Avertissement de basse tension et Buzzer
• Prise en charge Lipo 3s (Requis)
• 9XR firmware pré-installé
• AVR ISP interface
• Antenne interne 2,4 GHz
Ligne forums de support et d'emploi disponibles à l'adresse: http://www.turnigy9xr.com
Spec:
Affichage: 128 * 64LCD (rétro-éclairé)
Type de support: Heli / Acro / Glid
Mémoire Modèle: 16
Collez modes: 1, 2, 3, 4
Type de codeur: PPM / PCM
Module Interface: Compatible JR (Voir Articles connexes ci-dessous)
Simulateur Interface: Oui (JR & Futaba)
Buzzer: Oui
Requis:
Batterie Lipo 3S
Module RF
Inclus:
Turnigy 9XR émetteur (Mode 2 - Gaz à Stick analogique gauche)
Guide de démarrage rapide
Note: Cette version est livrée sans module RF, S'il vous plaît commander le module RF relevent de la liste des accessoires ci-dessous.
Jordan83
Message par Jordan83 » 25 déc. 2012, 21:30
Si on peut y mettre dessus les modules FRsky et pour le prix, je me laisserais bien tenter moi. :ph34r:
Merci pour la traduction.
FredoLaPower
Message par FredoLaPower » 25 déc. 2012, 22:49
Surtout que le soft derriere c'est clairemnt du Open 9x. Moi j'achete :)
Image Veneux les Sablons (77)
Image -
Image Eachine C129 (Firefox)
Image iCharger 106B+ | NPS700AB (700W/12V/57,6A)
Image Radiomaster TX16S Image RealFlight 7.5
[Sud Seine & Marne] Pilotes, spots & clubs
YenYen
Message par YenYen » 26 déc. 2012, 00:20
FredoLaPower a écrit :Surtout que le soft derriere c'est clairemnt du Open 9x. Moi j'achete :)
Moi aussi !
Et à 50$, je ne connais aucune radio offrant les mêmes performances, surtout que j'ai déjà la TGY9X et que je suis tout à fait satisfait pour ce qu'elle m'a couté, alors là c'est clair, je fonce ! :)
Pitch or die !!!
etien96ne
Message par etien96ne » 26 déc. 2012, 00:44
Moi je la trouve vraiment moche mais c'est vrai que c'est tentant vu le prix :p
Mais je pencherai plutot sur les radios Frsky qui ne devraient pas tarder a sortir ;)
Et eux c'est sur qu'ils ont developper leur radio avec les gars d'er9x et de open9x :D
gael123
Message par gael123 » 26 déc. 2012, 01:02
C'est vrai qu'elle est vraiment moche, la forme, a va encore, mais les 3 tonnes de chromes, dur ....
Je changerais pas spécialement ma 9x pour la 9xr, mais le jour ou j'ai un soucis avec je la prendrais, le look passe en second.
YenYen
Message par YenYen » 26 déc. 2012, 01:12
Voilà des infos pour ceux qui se posaient la question du FRsky et aussi ceux qui n'aiment pas le chrome ! :)
http://eastbay-rc.blogspot.fr/2012/07/i ... y-9xr.html
Pitch or die !!!
olivier30900
Message par olivier30900 » 26 déc. 2012, 07:40
Y'a quand même un soucis et pas des moindre : http://fpvcentral.net/2012/12/turnigy-9 ... g-the-gpl/
Vidéos FPV
Bilou34
Message par Bilou34 » 26 déc. 2012, 09:29
Je pense qu'ils vont faire leur mea culpa, qu'ils vont mettre les liens pour le téléchargement de la source et l'affaire seras close!
HK gagne un Max de fric sur le matos, le software ils s'en balance je suis sur!
En tous cas le rapport qualité/prix semble quand même dur à battre...
FredoLaPower
Message par FredoLaPower » 26 déc. 2012, 10:47
Le rappart Q/P est imbattable personne ne peut argumenter sur ca. Mais la qualite des potars et plastoque va avec le prix. Ceci dit ils vont vendre des facades intergengeables semble t il.
Image -
gael123
Message par gael123 » 26 déc. 2012, 10:54
Si la qualité est a peut prêt la même sur sur la 9x, y'a pas tellement a avoir peur, même si c'est vrai que c'est pas le top du top niveau qualité, c'est pas non plus de la bricole.
Yoy24
Message par Yoy24 » 26 déc. 2012, 11:25
Yop,
les stick sont monté sur roulements.... ai-je bien lue ??? :huh:
YenYen
Message par YenYen » 26 déc. 2012, 11:31
FredoLaPower a écrit :Mais la qualite des potars et plastoque va avec le prix
Sur ma 9X, j'ai absolument rien à reprocher aux potards 2 positions, par contre les 3 positions ont un peu de jeu mais sont quand même parfaitement fonctionnels, alors suffit d'ajouter quelques € pour acheter de bons potards et c'est nikel ! :)
Pitch or die !!!
SmallLama
Message par SmallLama » 26 déc. 2012, 12:30
il parle des potars des manches je pense.
ma flotte
AR7200, What Else ??
C.M.C
YenYen
Message par YenYen » 26 déc. 2012, 12:48
SmallLama a écrit :il parle des potars des manches je pense.
Si tel est le cas, autant pour moi, ceci dit jamais eu de soucis avec les miens, je touche du bois ! -_-
Pitch or die !!!
maxxis
Message par maxxis » 07 janv. 2013, 15:32
bon elle est en stock vite faut commander, je viens de la prendre en mode 1, par contre pour le module j'hésite, mais bon je pense prendre le frsky : http://www.hobbyking.com/hobbyking/stor ... II_RX.html
d'aprés vous c'est bon ? ce module est compatible ??
FredoLaPower
Message par FredoLaPower » 07 janv. 2013, 16:24
Dites les gars une idée sur où trouver un trainer switch pour la 9X ? Le mien a rendu l'âme...
Image -
FredoLaPower
Message par FredoLaPower » 07 janv. 2013, 16:29
maxxis a écrit :bon elle est en stock vite faut commander, je viens de la prendre en mode 1, par contre pour le module j'hésite, mais bon je pense prendre le frsky : http://www.hobbyking.com/hobbyking/stor ... II_RX.html
Oui il l'est.
Image -
maxxis
Message par maxxis » 07 janv. 2013, 17:00
merci pour la réponse ok c'est fait, pour l'accus celui la est compatible : http://www.hobbyking.com/hobbyking/stor ... a_JR_.html
maxxis
Message par maxxis » 22 janv. 2013, 20:23
bon je viens de recevoir la radio alors ma toute premiere impression à l'ouverture du carton grrrrr c'est petit, joli emballage, mais le truc le plus flagrant ca fait vraiment plastoc hummm , l'habillage fait plastoc , je sais pas ce que ca vaut, sinon la tenue en main bien pour moi, l'écran lcd est grand est beau tout en bleu, je vais faire des photos plus tard .....
chriscool
Message par chriscool » 26 janv. 2013, 21:52
gael123 a écrit :Si la qualité est a peut prêt la même sur sur la 9x, y'a pas tellement a avoir peur, même si c'est vrai que c'est pas le top du top niveau qualité, c'est pas non plus de la bricole.
Nos amis australiens trouvent quand même que HK a raté un peu le virage... à moins qu'ils ne corrigent rapidement les soucis de qualité du matériel et d'un design pas toujours bien vu (p. ex. le switch "trainer" trop éloigné).
http://www.youtube.com/watch?v=SWYW2QYKrL4[/video]
Peut-être vaut-il mieux attendre la prochaine FrSky qui ressemble ééééénormément à une JR 9503 (ou DX9), mais qui semble de meilleure qualité (enfin, à voir une fois que quelqu'un l'aura entre les mains pour la question qualité des matériaux):
Duplex X9D
BlackBear
Message par BlackBear » 09 févr. 2013, 01:08
Salut à tous.
Je viens de commander la 9xr et le module Orange TX DSM2/DSMX. (+2 Rx 9ch)
Besoin de satellites en plus?
J'ai commandé la version mode 1 car la mode 2 n'est pas disponible pour le moment. J'ai vu la vidéo pour la transformer mais je n'ai pas compris pourquoi une fois débranchées, il n'intervertit pas directement les sticks plutôt que tout démonter le système de ressort. Les blocks de sticks ont l'air d'être les même. Je me trompe?
J'en profiterai pour poncer les boutons qui ont l'air d'être mal ébavurés de base.
Après mise à jour ou pas? et surtout quel firmware prendre avec quelles options sur le 9companion. J'ai pas encore trop saisi...
Avion: Plein de trucs ^_^
Télécommande Spektrum DX9
FredoLaPower
Message par FredoLaPower » 09 févr. 2013, 01:58
BlackBear a écrit :Salut à tous.
Oui. fais la modification avec les ressors. Sinon tu vas devoirs débrocher les nappes... Et là si tu te plantes en remontant... Aie...
Je te conseilles Open9X coupler avec Companion9X. L'intérêt c'est que tu pourras avoir le firmware en français.
Image -
Big Lama 07
Message par Big Lama 07 » 09 févr. 2013, 20:10
Je me décide à commander une 9x, mode 2. Est ce que cette clé convient pour flasher :
http://www.eastdiyshop.com/USB-ASP-USB- ... p-153.html
Que me conseillez vous en Rx 9 voies?
Merci pour vos conseils
Noël
Bons Vols à Tous
Image Big Lama 07
Image ESky Nano - Big Lama Image V911 Image Honey Bee CPX et CP3 (A vendre) - HKatastrophe 450 (mulet) - Trex 450S Airwolf - Trex 450S Bell 206
Image Devo 10 Image Phoenix V5Image Imax B6 / Alim PC 160W
Image HK Bixler V1 -Bricoles en dépron Image Auto RC - Moto RC et Vrai - Voilier 1m RC Image
FredoLaPower
Message par FredoLaPower » 09 févr. 2013, 22:44
Oui c'est ce qu'il te faut. Mais ce fil est dédié à la 9XR.
Image -
Big Lama 07
Message par Big Lama 07 » 10 févr. 2013, 00:13
Bonsoir à tous,
Alors Fredo, on s' est déjà contacté!!!!! Dommage d' avoir loupé ton offre :( .
Pourquoi dédié à la XR? J'ai vu sur des posts qu' il suffisait de souder quelques fils d' une prise 10 connexions pour avoir ce qu' il fallait, c' est parti :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes:
Pourquoi la T9?: parcequ' elle est livrée complète.
J' ai trouvé en sctock une T9. Si ce n' est pas le bon ( le câble), que me faut il ???? Si j' ai bien compris, c' est le module qui commande le RX. Pour le futur, J' ai vu aussi un module pour télé métrie (F...... Y) et donc, quel récepteur? Pour que cela marche, il faut donc aussi des "émeteurs" sur l' hélico qui communiquent avec le RX?
Malgré vos précédents conseils, COMME JE SUIS COMPLETEMENT PERDU: S O S
Merci à vous tous
Bons Vols à Tous
Image Big Lama 07
FredoLaPower
Message par FredoLaPower » 10 févr. 2013, 01:16
Big Lama 07 a écrit :Bonsoir à tous,
Vendu à contre coeur mais bon elle fera un heureux.
Parce que blacline l'a ouvert pour parler de ce modèle en particulier.
Honnêtement je te propose plutôt de prendre cela: http://www.smartieparts.com/shop/index. ... cts_id=331
Comme ça tu n'auras pas de soudures à faire et pas plus à acheter un adapteur USB/ASP
De toute manière la 9XR a plutôt mauvaise pub.
Pas compris.
Un module FrSky DJT + RX 8RII. J'en vends un dans les petites annonces. Comme plus haut si tu n'es pas fan des soudures: http://www.smartieparts.com/shop/index. ... cts_id=337
Merci à vous tous
Il ne te faut que de la patience pas de panique.
Image -
Big Lama 07
Message par Big Lama 07 » 10 févr. 2013, 10:37
Merci fredo pour ta réponse. En ce qui concerne la carte de flash, as tu une Ref pour l' éclairage? Je n' ai pas bien compris l' usage de ça http://www.smartieparts.com/shop/index. ... cts_id=337? En ce qui concerne ton annonce, MP
Bonne journée à tous
Bons Vols à Tous
Image Big Lama 07
BlackBear
Message par BlackBear » 25 févr. 2013, 18:23
j'ai cette télécommande qui vient d'arriver, je vais l'utiliser sur mes avions, ma Mx16 Graupner pour mes hélicos.
J'ai vérifié les boutons, aucuns n'accrochent. Cool.
1° étape, la changer en mode 2... Je vois ça ce soir. J'attends encore le câble de programmation pour flasher le firmware.
BlackBear
Message par BlackBear » 26 févr. 2013, 11:21
J'ai essayé de voir si il y avait moyen de gruger un peu tout le montage/démontage pour passer en mode 2 la télécommande, et je confirme que ce n'est pas possible.
C'est pas dur à faire, juste un peu ennuyeux.
Je l'ai testé un peu sur simulateur (Next et Phoenix). Ça a l'air de bien fonctionner. C'est vrai que l'inter du Trainer est un peu loin, même avec mes grandes mains.
nonoz1000
Caporal
Message par nonoz1000 » 02 mars 2013, 23:10
Salut a tous, je viens de craquer au vues des possibilités de cette radio, j'ai donc commandé une t9XR. En attendant de la recevoir, j'ai commencé a faire le tour de companion9x pour bien en comprendre le système et la programmation car en arrivant la 9XR va être flashée en open9x fr directement.
La programmation de companion me paraît assez intuitive, mais je cale sur un détail.
Afin de comprendre le principe de programmation, j'ai pris le problème a l'envers. Soit j'ai ouvert une eeprom neuve, et en model 1 j'ai chargé un gabarit, j'ai choisi hélicoptère avec contrôle du gain gyro).
J'ai compris l'essentiel de la programmation, mais un détail me titille.
Lorsque je met la simu radio, les servo CYC 1 à 3 bougent bien avec le cyclique (voies 1 à 3), cependant lorsque l'on touche au pas, les voies 1 à 3 ne réagissent pas.
Est ce que le gabarit n'est pas fonctionnel et demande d'être fini ?
Ou bien est ce que pour des soucis de simplicité de lecture des voies simu, le report de la voie fictive 11 n'est envoyé sur les voies 1 à 3 ?
Corbeil essonnes
Yam YZF1000R thunderace et 650 dominator supermot
Ancien helico : HB CP2 , HB Cool , HB King 2
Helico actuel : TRex 450 se et Dragonus Elite, CopterX 500
Graupner MX12S modée 2,4 ghz, Turnigy 9XR open 9x
nonoz1000
Caporal
Message par nonoz1000 » 10 mars 2013, 13:45
Personne pour me renseigner ?
Corbeil essonnes
nonoz1000
Caporal
Message par nonoz1000 » 10 mars 2013, 19:24
réponse trouvée....
Corbeil essonnes
FredoLaPower
Message par FredoLaPower » 10 mars 2013, 21:17
Tu trouveras ton bonheur ici:
viewtopic.php?f=122&t=44535
Image -
nonoz1000
Caporal
Message par nonoz1000 » 10 mars 2013, 21:32
Je n'ai pas trouvé la réponse dans le post mentionné.
En fait le problème que j'évoque sur la simulation émetteur vient d'un bug de C9x depuis les dernières 3 versions à priori. Si l'on règle la radio via C9x sur l'ordi, sur le profil hélico, il faut choisir CYC1 en source pas collectif et non voie11 sinon le mixage vers les voies 1 à 3 ne se fait pas.
Voilà, si cela peut servir a quelqu'un
Corbeil essonnes
Eurny666
Message par Eurny666 » 13 mars 2013, 20:27
Salut!
Je voulais savoir si quelqu'un utilise cette radio pour le FPV et notamment avec la fonction Head Tracking?
Image 13 - Les Pennes Mirabeau / 23 ans Image DJI F330 TBS style -FPV- (125 vols)
Image Trex 450 SE -FBL- (223/2) Image Trex 250 PRO -DFC- (81/3 crashes)
Image Calmato ST GP 1400 (8/1) Image Skywalker 1900 -FPV- (20 vols)
Image Mini Skywalker -FPV- (90 vols) Image Swift II -FPV- (91 vols)
Image DX7 / Turnigy 9x + FrSky pour le FPV --- Image Ultramat 16 / ECO6 / AP6210
chtipanda
Message par chtipanda » 31 mars 2013, 14:44
je vient de traduire la notice avec mon ami google mais il n est pas expert dans ce domaine
apres quelques heure de travail ça donne ceci
notice française
il parle de la fonction utilisable via les mixage :wub:
c est pour cela que je l ai prise d ailleurs
43 ans -lille
http://chtipanda.free.fr/
Thenewhdd
Sergent
Message par Thenewhdd » 21 avr. 2013, 19:35
Salut !
Je viens d'en acheter une ! Pour info elle est testée et détaillée avec l'ER9X ici :
http://www.bungymania.com/technic/index ... xr_p1.html
Version Open9X ici :
http://www.bungymania.com/technic/index ... xr_p2.html
