FBL units
- Rich Knapp
FBL units
Well, I planed on a bD 3SX on my 2nd OXY 3 seen I have a extra 3SX.
Plan changed to a Brain.
The 3SX will take to much changing the frame and the FBL case. Way more than I like to do so I'm going to a Brain on it.
BEC is already installed so I will leave it on there.
Team Lynx & OXY HELI Manager
- KRoMoZoM_21
Re: FBL units
Hi,
The bavarian is already too big on a 450 heli size .
I have an sk540 on my mine, and it insert just with velcro (hook and loop).
Edit : Le bavarian est déjà trop gros sur un 450. J'ai un sk540 sur le mien, et ca rentre juste avec le vecro.
Re: FBL units
Yop)
Merci Krom... pour l'effort de traduction...
- Le Docteur
Re: FBL units
Oh oh ! How many days ?Otatiaro a écrit :Hello,
If you can wait a couple more days .......
Thomas.
Combien de jour M. Thomas ?
Bien Amicalement,
Re: FBL units
Can't say anything yet, but not too long (a few weeks maybe ?).
Thomas.
Thomas.
Support : contact@eznov.com
- lolo63
Re: FBL units
This is why the 3D printer on heater
a FBL unit made in france??
padawan de steph66
Clermont-Ferrand (63) 32 ans
DX1Ot monomanche
Nano CPX;Trex150
Goblin 700 => neuron
Oxy3 qube =>beastX
DX1Ot monomanche
Nano CPX;Trex150
Oxy3 qube =>beastX
- BlackBear
Re: FBL units
Arf!!!!!!!!!!! Thomas!!!!!!!!! New gyro is already ready?
Avion: Plein de trucs
Télécommande Spektrum DX9
- KoRn_BeeF
Re: Re : FBL units
????????Otatiaro a écrit :Hello,
Thomas.
Moi je suis encore a l'école
Unit one lesson one :
What that mom ??.............
Modifié en dernier par KoRn_BeeF le 29 mars 2015, 23:46, modifié 1 fois.
Multi-rotor : GEP210
Avion : EXTRA 330SC 1.85m
Mon Thingiverse
Mon Thingiverse
- Rich Knapp
Re: FBL units
Another guy is running a 3SX on his OXY, but he did some filing down on the case ears. I don't want to do that.
IF I filed off the ears and CA glued the case it would be ok. (case minus ears is smaller than a iKon/Brain) I don't want to mod the case. I'll just use it on another bird. Just thought I could find a way of mounting.
I have to wait for my DSMX sat to come in so I have to wait. Weather took a turn for bad anyways. BAD wind, rain and snow.
- Rich Knapp
Re: FBL units
Thomas.
Sounds interesting.
I'm watching you. lol
Re: FBL units
Sur le mien c'est un spirit
JR Forza 450 ex,spirit
OXY 4 6S spirit
MINICOMET spirit
radio DX9
VTT Kona process 111 DL......
OXY 4 6S spirit
MINICOMET spirit
radio DX9
- KoRn_BeeF
Re: Re : FBL units
Il y aura moyen de tester au meeting ??derailleur a écrit :Sur le mien c'est un spirit
Mon Thingiverse
Mon Thingiverse
Re: FBL units
That's sweet words i like to hearOtatiaro a écrit :Hello,
Thomas.
Ce sont des mots que j'aime entendre
Padawan de Zaadum
Trex 250 pro dfc,
Radios Spektrum dx8 et dx6i
Trex 250 pro dfc,
Re: Re : FBL units
Oui sans problèmeKoRn_BeeF a écrit :Il y aura moyen de tester au meeting ??derailleur a écrit :Sur le mien c'est un spirit
OXY 4 6S spirit
MINICOMET spirit
radio DX9
OXY 4 6S spirit
MINICOMET spirit
radio DX9
- fabu74
Re: FBL units
Ça donne quoi ce spirit Dérailleur?
- KoRn_BeeF
Re: Re : FBL units
Merci d'avancederailleur a écrit : Oui sans problème
Mon Thingiverse
Mon Thingiverse
Re: FBL units
Ça donne rien pour l'instant, les dampers que m'a envoyé loki sont arrivés aujourd'hui et me permettent de dépanner l'oxy mais moi suis en déplacement à canjuers avec l'armée pour toute la semaine (suis réserviste). Quand je vous dis que j'ai jamais de temps.... D"un autre côté tempête de vent en ce moment.fabu74 a écrit :Ça donne quoi ce spirit Dérailleur?
OXY 4 6S spirit
MINICOMET spirit
radio DX9
OXY 4 6S spirit
MINICOMET spirit
radio DX9
Re: FBL units
23mm width is ok on the Oxy ? (34mm long)Rich Knapp a écrit :Well, I planed on a bD 3SX on my 2nd OXY 3 seen I have a extra 3SX.
Thomas.
Re: FBL units
Mais non, il y a juste un leger courant d airderailleur a écrit :D"un autre côté tempête de vent en ce moment.
40 avec rafales a 55, tout le monde a volé cet aprem meme papy en 130X
- KRoMoZoM_21
Re: FBL units
30mm + le velcro, ca passe (juste, mais ca passe ), donc ton module devrait le faire sans probleme.Otatiaro a écrit :23mm width is ok on the Oxy ? (34mm long)
Thomas.
- Rich Knapp
Re: FBL units
Max OXY 3 FBL mount is 28mm wide by 40mm long.Otatiaro a écrit :23mm width is ok on the Oxy ? (34mm long)Rich Knapp a écrit :Well, I planed on a bD 3SX on my 2nd OXY 3 seen I have a extra 3SX.
Thomas.
Any wider and the frame will be clamping on the unit.
bD 3SX is 34mm wide with ears and 30mm without ears.
Ears are were the case is screwed together.
You can as listed use velcro instead of mounting tape to raise it up over the frame if it is a shorter unit.
I personally like to use the 3M outdoor 4011 two sided mounting tape. Just my opinion but I feel the valcro has to much movement for a unit to be consistent. Even strapped down hard.
- KRoMoZoM_21
Re: FBL units
Haha, i don't use a hook n'loop to fix the modul. The modul is fixing with double sided tape, and is maintaining by the hook n'loop around it.
Hihihohahaha, J'utilise pas le velcro pour fixer le module. Le module est fixé au double-face, et assuré par le velcro autour.
- Rich Knapp
Re: FBL units
General comment. I have heard of some people doing it.KRoMoZoM_21 a écrit :Haha, i don't use a hook n'loop to fix the modul. The modul is fixing with double sided tape, and is maintaining by the hook n'loop around it.
Re: FBL units
À canjuers autour de 100 /110. Tout a valdingué sur le dépôt et on a refait les pleins des pompiers le soir qui étaient intervenus sur une toiture envolée et un départ de feupachy a écrit :Mais non, il y a juste un leger courant d airderailleur a écrit :D"un autre côté tempête de vent en ce moment.
OXY 4 6S spirit
MINICOMET spirit
radio DX9
OXY 4 6S spirit
MINICOMET spirit
radio DX9
- Rich Knapp
Re: FBL units
I made it fit.
I'll get a vidio next time I get to fly.
6S and the 3SX are gold.
SE has a killer piro rate compaired to my other orange 6S
