Les Lipos G4 arrivent
- Jonathan06
Lisez plutôt ca:
En voici un exemple:
http://www.fast-lad.co.uk/store/tp2650- ... -8706.html" onclick="window.open(this.href);return false;
This is the Thunder Power Pro Power "G4" 45C, 6S, 22.2V, 2650mAh Li-Polymer Battery. Thunder Power G4 series batteries deliver the same mAh capacity as previous Thunder Power batteries, but with upwards of 40% more power and 6-times more cycle life than most other 25C to 40C+ continuous discharge rate capable batteries! This makes them the perfect choice for use in a wide variety of aircraft. The 6S 22.2V 2650mah battery is the most powerful battery ever made available for powering 500-class 3D helicopters.
Features:
Exclusive Generation 4 (G4) chemistry offers a never before seen revolution and evolution in LiPo cell performance with up to 40% more power, 6-times better cycle life delivery and ultra-fast 6C charge rate capability!
Offers the industrys absolute highest level of power delivery available at the lowest possible weight, delivering up to 40% more power at the same or even lower weight than most other brand 25C to 40C+ rated batteries.
Industry-leading cycle life and longevity up to 6-times better than other brands offers long lasting value and performance WITH NO DISCERNIBLE LOSS OF POWER DELIVERY FOR THE FIRST 100-200+ CYCLES
Perfectly suited for pylon racer, electric ducted fan (EDF), F5B/F5D and other high-power airplane applications and the best choice for maximum power and cycle life delivery for 250 to .90/700-size extreme 3D performance helicopters
Capable of continuous discharge rates up to 45C and burst discharge rates up to 90C, delivering higher voltage under typical and heavy loads than all other 25C to 40C+ continuous discharge rated batteries
Capable of being charged safely at rates up to 6C for ultra-fast charge times of 10 minutes or less WITH NO REDUCTION IN CYCLE LIFE DELIVERY! (When charged using approved charger/balancer combinations only)
Cells are built using premium quality Japanese-made materials, including the latest in super-fine substrate (nano) materials and technology to offer vastly superior power, capacity and cycle life delivery never before seen
Cells are matched by true internal resistance, capacity and voltage for maximum power and cycle life delivery with packs PROUDLY ASSEMBLED IN THE USA by Thunder Power RC in Las Vegas, Nevada
The series of choice for top pilots like Alan Szabo, Jason Krause, Bert Kammerer and many others, as well as BVM, Inc. for powering their incredible, large-scale EDFs to speeds in excess of 230MPH
Includes 1-year manufacturers warranty and 1-year 50% off Damage Replacement Program coverage offering the best warranty and support
Type: Lithium Polymer
Capacity: 2650mAh
Voltage: 22.2V nominal
Number of Cells: 6
Weight: 434 grams
Configuration: 6S
Dimensions (LxWxH): 128x42.0x40.0mm
Maximum Continuous Discharge: 45C (119A)
Maximum Burst Discharge: 90C (238A)
NOTE: When using high energy Li-Polymer Batteries, please do not over-discharge or over-charge batteries as this will result in over heated batteries. Discharging capacity can't exceed 80% of the max capacity of the pack after full charging to ensure a good cycle performance. It is recommended to fully charge a brand new battery before using and only discharge the battery 50% for first 5 cycles. Always set a low voltage warning on ESC (End voltage cannot be lower than 3.2v per cell). Do not use a battery that has too low a voltage.
Do not expose batteries to sunshine or store/charge batteries at the temperature above 35°C or in a closed car. The high temperature environment could cause damage to the pack or make it burst. If the battery becomes hot while fast charging, high current discharging or driving, do not charge the battery until it has cooled completely. Wait about 20 mins, then inspect prior to recharging.
Videos: Page Perso
