Posté : 06 oct. 2009, 18:21
par Siza
Ca se passe ICI
Pensez a prendre et a installer avant tout les VCP Drivers ICI
Procédure de mise a jour ICI
Changements:
v3.2 (the first fw update release for hardware v3 NET & DUO)
* Added Terminal Voltage Control Function (TVC). You MUST read this EXPLANATION before using TVC!!
* Changed Cooling Fan control such that the fan is stays on if case temp exceeds 45C, until falling below 40C.
NOTE: This release is NOT compatible with EOS Insight Logging Software. If you need to use the logging software, please delay your update until about Nov 1st 2009, when we will release one more FW update and a revised EOS Insight to match.
Voila :)
Posté : 06 oct. 2009, 18:57
par RolluS
Merci ;)
