Page 1 sur 5
ATTENTION RAPPEL USINE des Castle Creation Ice 120 HV
Posté : 25 juil. 2011, 20:13
par flyingsoon
Salut à tous les heureux possesseurs (jusque là) ou malheureux (n'est-ce pas Laurent) de contrôleurs Castle Creation Ice 120 HV et à tous les autres...
Je vous transmets ci-joint le mail de Castle Creation qui rappelle tous les contrôleurs CC Ice HV 120 à l'usine pour modif avant de nous les renvoyer!!!
Merci de préciser si certains d'entre vous ont eu des problèmes... Apparemment, le risque, c'est tout simplement que ça crame!
Hello all,
While Castle takes all controller failures seriously, many have felt that our response to the incidences of failures in our Phoenix Ice 120HV was taking too long. We didn't make any official statements as we couldn't identify any particular pattern or cause for the failures. Our Repair Dept. keeps track of our returns - for any reason -- and the returns of the 120HV were actually very low; less than 3%. We generally see more than that rate of return just from crash damage unrelated to the controllers. Given that we've produced more than 10,000 of these controllers, a low percentage of failure still results in a lot of upset customers.
We've recently determined that some, again some, setups stress particular components in a way that causes the controllers to fail instantly. The failure mode allows a complete short circuit to occur. Our controllers are designed to carry high currents with as little resistance as possible. This is advantageous when the controllers are operating properly, but this leads to extreme currents and heat when the controllers fail. As the ICE controllers are encapsulated in metal heatsinks, this heat is further concentrated such that physical injuries or property damage may occur.
Our engineers have tested a hardware modification that greatly reduces the risk of this particular failure. We do not recommend using Phoenix Ice 12HV controllers until they have been modified to this new standard.
Please return any 120HV controllers that you may have for one that has this modification. There will be no charge for this exchange.
Please advise anyone using a 120HV controller of this notice.
REPLACEMENT PROCEDURE
Click this link and follow the directions to process your return.
North American customers please ship to Castle in Kansas via a traceable delivery service:
CASTLE CREATIONS, INC
120HV SERVICE / Service Department
540 N.ROGERS RD.
OLATHE, KS 66062
European customers may return their controllers via a traceable delivery service to our new European repair center:
CASTLE CREATIONS EUROPE BVBA
120HV SERVICE
GEELSEWEG 80
2250 OLEN
BELGIUM
Please be sure to include a copy of the order confirmation in your package.
NOTE: For purposes of fast turnaround, you will be sent another Phoenix Ice HV 120 controller. Remove all connectors, etc. from your ESC before shipping as they will not be returned with your replacement controller.
Our Technical Support and Repair staff do not have any additional information, calling them will only lead to additional frustration for all involved. We will advise you via email of the expected shipment date for your return.
We apologize for any problems this matter may have caused, and we hope that our candor and willingness to repair these controllers will help maintain your trust in our products and service.
Thanks,
Team Castle
A bon entendeur!
Re: ATTENTION RAPPEL USINE des Castle Creation Ice 120 HV
Posté : 26 juil. 2011, 09:14
par Yoy24
Alors que le château prend toutes les défaillances de contrôleurs au sérieux, beaucoup ont estimé que notre réponse à l'incidence des échecs dans notre 120HV Phoenix glace était trop long. Nous n'avons pas fait de déclarations officielles que nous n'avons pas pu identifier toute tendance particulière ou de cause pour les échecs. Notre département de réparation garde la trace de nos retours - pour une raison quelconque - et les rendements du 120HV étaient en réalité très faible, moins de 3%. On voit généralement plus que le taux de rendement juste de dommages accident sans rapport avec les contrôleurs. Étant donné que nous avons produit plus de 10.000 de ces contrôleurs, un faible pourcentage d'échec des résultats encore dans beaucoup de clients mécontents.
Nous avons récemment déterminé que certains, encore une fois certains, le stress des configurations des composants particuliers d'une manière qui entraîne les contrôleurs à l'échec instantanément. Le mode de défaillance permet un circuit complet courte de se produire. Nos contrôleurs sont conçus pour transporter des courants élevés avec une résistance aussi peu que possible. Cela est avantageux lorsque les contrôleurs fonctionnent correctement, mais cela conduit à des courants extrêmes et la chaleur lorsque les contrôleurs d'échouer. Comme les contrôleurs de l'ICE sont encapsulés dans des radiateurs en métal, cette chaleur est ensuite concentré tels que les blessures physiques ou des dommages matériels peuvent survenir.
Nos ingénieurs ont testé une modification matérielle qui réduit considérablement le risque de cet échec. Nous ne recommandons pas d'utiliser les contrôleurs de glace Phoenix 12HV jusqu'à ce qu'ils aient été modifiés pour cette nouvelle norme.
S'il vous plaît retourner tout contrôleurs 120HV que vous pouvez avoir un qui a cette modification. Il n'y aura pas de frais pour cet échange.
S'il vous plaît aviser quiconque utilisant un contrôleur de 120HV du présent avis.
PROCÉDURE DE REMPLACEMENT
Cliquez sur ce lien et suivez les instructions pour traiter votre retour.
Clients nord-américains s'il vous plaît navire à Château dans le Kansas via un service de livraison traçable:
Castle Creations, INC
120HV Service / Service Department
540 N. Rogers RD.
Lenexa, KS 66062
Les clients européens peuvent retourner leurs contrôleurs via un service de livraison traçable à notre nouveau centre de réparation européen:
CREATIONS château d'Europe BVBA
120HV SERVICE
Geelseweg 80
2250 Olen
BELGIQUE
S'il vous plaît n'oubliez pas d'inclure une copie de la confirmation de commande dans votre forfait.
NOTE: Aux fins de la rotation rapide, il vous sera envoyé un autre Phoenix Ice HV 120 contrôleur. Retirez tous les connecteurs, etc de votre ESC avant l'expédition comme ils ne seront pas retournés avec votre contrôleur de remplacement.
Notre support technique et le personnel de réparation n'ont pas toute information complémentaire, les appelant ne fera que conduire à la frustration supplémentaire pour toutes les personnes impliquées. Nous vous conseillons par mail de la date d'expédition prévue pour votre retour.
Nous nous excusons des problèmes que cela peut avoir causé la matière, et nous espérons que notre candeur et la volonté de réparer ces contrôleurs aideront à maintenir votre confiance en nos produits et services.
Merci,
Posté : 26 juil. 2011, 09:27
par Gasoil4ever
Sont trop fort ces Ricains !
"Quelques, nous disons bien quelques contrôleurs ont eu des problèmes, liés à certaine configuration, moins de 3% sur 10.000 blblablablalbal. Bref c'est pas grave et c'est pas de notre faute. C'est jparce que nos contrôleurs permettent de passer beaucoup de courant sans résistance. Bref c'est juste parce qu'ils sont trop bien qu'ils crament.
En gros c'est pas un défaut, mais la resultante d'une qualité
On vous le répète c'est pas grave, mais nous vous recommandons de ne pas voler avec ce type de matériel, de nous le renvoyer à nos frais pour échanges, et d'en informer tous les utilisateurs que vous connaissez..."
AHAHAHAHAHAHAAH
Posté : 26 juil. 2011, 10:08
par chamois06
Combien de constructeurs de matériel de modélisme ont une attitude de responsable en rappelant du matériel défectueux? Il y en a mais pas assez
J'ai des ICE , pas le 120HV, et j'ai reçu le courriel de CC.
Je dis bravo même si il aurait mieux valu mettre sur le marché un produit parfaitement fiable, au moins ils reconnaissent et acceptent leur erreur plutot que de faire le "canard" et de traiter en douce, au coup par coup, les plaintes clients.
Pierre
Posté : 26 juil. 2011, 10:17
par Towcat
absolument.
pareil que Chamois j'ai un Ice100, j'ai reçu quand même le courrier.
Clair que je vois mal HobbyKing m'envoyer un mail pour me dire qu'une série de moteurs défectueux a été vendue...
(ce qui doit arriver courament)
Posté : 02 août 2011, 22:45
par Chris Millers
Je suis en cours de montage d'un Trex 700E doté d'un CC Ice 120 HV neuf bien sûr.
Parfaitement au courant de tous les problèmes de CC qui crament, et inquiet en ce qui concerne les prochains vols de mon 700E, j'ai donc, suite au message de CC, renvoyé le mien en Belgique vendredi dernier.
Ce qui serait sympa, pour ceux qui ont fait la même opération, c'est de se tenir informé de la suite des évènements : contact éventuel de la part de CC, délai de retour, aspect extérieur du retour, résultats des premiers essais avec le nouveau contrôleur modifié, etc...
Cela nous permettra de nous rendre compte rapidement si les modifs sont efficaces à 100%, ou si il y en a encore certains Qui crament. J'espère que non et que ce cauchemard est terminé!
Pour ma part, je n'y manquerai pas, d'autant plus que je connais des potes qui attendent de "voir" ce que vont donner les premiers essais des "retours" avant d'envoyer le leur.
Dans un premier temps, je trouve qu'il serait intéressant de savoir si nous sommes nombreux à l'avoir retourné?.......
Merci à tous de votre participation.
A bientôt j'espère.
Chris
Posté : 03 août 2011, 07:42
par christian57200
Salut a tous
J'ai renvoyé le mien également cela fait 1semaine en Belgique.
J'ai fait une 15 de vols avec sur mon 700 (simple translations ) sans soucis mais je ne suis pas un adepte de la roulette russe donc j'ai procéder a l'échange.
Posté : 13 août 2011, 10:47
par ced69
Hello, ayant eu des renseignements d'un gros revendeur Align en Suisse, 99% des Esc Castle crame au premier branchement. D'autres ont cramé suite à des mauvaises manip de ces clients. J'ai 110 vols avec le mien d'origine. No blème.
Pourvu que cela dure.
PS: Il à aussi des clients qui on renvoyé un qui allait bien et quand ils ont reçu le nouveau de Belgique il à cramé !
Posté : 13 août 2011, 11:05
par christian57200
les retours qui crament s'est pas fait pour rassurer ?
Pour moi toujours pas de nouvelles depuis le 29 juillet
Que faire garder le CC ou changer mais s'est Mme qui va pas être contente vu les tarifs des contro
Posté : 23 août 2011, 00:17
par Beni540
je suis un "heureux" possesseur d'un contro CC ice hv 120 et je l'ai renvoyé aujourd'hui en belgique... Mon premier vol avec mon trex 700 s'est bien passé (stationnaire seulement, mais quel intensité <3) mais j'ai remarqué que le contro chauffait enormement par rapport aux autres controlleurs... bref un coup d'oeil sur le forum et voila que j'apprend qu'il y a un defaut de fabrication... imaginez la frustration -.-
quelqu'un sait si les frais de renvoie en belgique sont a charge du fabricant ou du client? en toute logique, c'est la faute a CC et donc a leur charge... mais j'ai regardé sur leur site, et rien n'y est precisé ( mon anglais me jouerait des tours?)
Je vous ferait part s'il y a du nouveau a propos du temps de reparation et de renvoie... a moins que christian (ou d'autres) le reçoit avant moi...
et... CA M'ENERVE!
Posté : 23 août 2011, 09:18
par christian57200
Alors frais de port à ta charge pour l'envoi et le faire avec suivi .
Le mein est arrivé le 29 juillet et toujours rien mais j'ai reçu dimanche un nouveau mail comme quoi même ce de retour de SAV (portant un autocollant REV 3) devrait être renvoyé
Par contre dans le nouveau message il est bien stipuler qu'ils ne savent pas le délai pour un retour
Super ben CC, pour ma part j'ai réinvesti dans un YGE 120HV car si çà dure 6 mois .
Posté : 24 août 2011, 10:14
par loulouroger
Bonjour a tous,
Vu que le rappel s est étendu a toute la série des HV chez Castle, le mien(ICE HV 80)est parti hier pour la belgique.
Les modéles qui sont "réparés" ou "remplacés" et s'appellent "ICE 2 HV"
A suivre...
Posté : 25 août 2011, 21:39
par FAISAN 77
Salut, j'ai un PHOENIX ICE 100 sur mon T-REX 550 FBL avec moteur NEU 1907/1Y en mode gov et après 5mn de statios ou de translations lentes ils sont tous les deux bouillant en fin de vol alors que mes VOLTZ 6S 5100 45C rigolent.
Pensez-vous qu'il soit concerné par le rappel car j'ai acheté l'hélico d'occasion donc pas reçu de mail.
Posté : 25 août 2011, 22:10
par loulouroger
FAISAN 77 a écrit :Salut, j'ai un PHOENIX ICE 100 sur mon T-REX 550 FBL avec moteur NEU 1907/1Y en mode gov et après 5mn de statios ou de translations lentes ils sont tous les deux bouillant en fin de vol alors que mes VOLTZ 6S 5100 45C rigolent.
Salut Faisan 77,
Pour infos voici le lien du rappel des contro Castle, n'est concerné que la serie des "HV" et "MAMBA XL":
http://www.castlecreations.com/support/ ... icehv.html
Donc pas de renvoi en belgique en ce qui te concerne.
Posté : 26 août 2011, 08:34
par FAISAN 77
Merci, LOULOUROGER,
Je vais donc passer progressivement de 5mn à 9mn de vol mais j'ai peur que la température monte encore un peu plus proportionnellement à la durée de vol.
Posté : 26 août 2011, 11:14
par den
peut-être des courbes pas/gaz mal adaptées ainsi que le pignon.
il vaut mieux avoir un petit pignon pour pouvoir tourner avec un régime moteur assez rapide car si on veut diminuer les tours moteur pour tourner moins vite au rotor on arrive vite a des rendements moteur pas terribles avec les chauffes associées.
Penser qu'en statio et translations lentes, on tire plus qu'en translations normales et la ventilation n'est pas forcément optimum.
Posté : 29 août 2011, 21:48
par Beni540
voila ce qui vous attend si vous utilisez un ESC CC ICE HV ayant le problème de construction:
http://www.youtube.com/watch?v=Q8q39XCk ... re=related
Posté : 31 août 2011, 21:17
par erfrance60
Bonsoir.
Je suis en train de monter en brancher mon 2eme Helico. TREX700E. J'ai acheté récemment le CC ICE HV 120 et je viens de tomber sur cet article.
Qui a reçu son Controleur aprés l'avoir envoyé?
Beaucoup d'entre vous l'ont envoyé en Belgique mais je n'ai toujours pas lu une personne l'ayant récuperé.
J'hésite à l"envoyer, surtout pour faire du vol maquette je ne pense pas qu'il chauffe trop.
Débutant je poserai quelques questions à des habitués lors du Sympio à Amiens le 10 et 11 septembre.
Quasi sur de voir du Trex 700E et un CC ICE HV 120.
Bon vol.
Posté : 31 août 2011, 21:36
par den
Ce n'est pas un question de chauffe ou de vol tranquille. Il y en a qui crament dès le premier branchement et d'autres au sol ou juste au décollage (voir vidéo ci-dessus). Et cela risque d'être long car il viennent juste d'identifier le problème, les premiers qui étaient partis et revenu n'étant pas guéris.
si tu as envie de prendre le risque, bien à toi...
Posté : 31 août 2011, 23:02
par Beni540
d'où est ce que tu tires tes news? le fait qu'ils viennent tout juste d'identifier le problème? Source officielle?
... je suis au fond du goufre avec cette histoire...
moi qui me réjouissait tant de profiter de mon nouveau trex 700 pour les vacances...
Posté : 01 sept. 2011, 00:59
par den
Il y a un post sur France hélico ou l'on voit la chronologie et qui contient quelques liens intéressant :
http://www.france-helico.com/viewtopic.php?f=5&t=41965
notamment cette analyse sur RCgroups :
http://www.rcgroups.com/forums/showpost ... tcount=103
Et la réponse du président de CC :
http://www.rcgroups.com/forums/showpost ... tcount=116
Donc à la date du 16 aout, il étaient en train de chercher/tester les remplacants des composant incriminés par un fabriqué à leurs spécifications, ce qui ne laisse pas augurer d'un dénouement très rapide à mon humble avis.
We are moving to a larger gate driver (a custom built for us by IR)
"We are moving " c'est plus du genre "on se dirige vers", ce n'est pas "on a le composant et il n'y a plus qu'a le remplacer".
Bon aller, la bonne nouvelle pour la fin :
http://www.rcgroups.com/forums/showthre ... 49&page=26
Ca va arriver doucement, mais plus lentement en belgique qu'aux US
Posté : 12 sept. 2011, 15:54
par den
Bon, ben c'est pas gagné. Si vous voulez voler un jour en étant tranquille coté ESC, vous devriez penser à une autre marque
http://www.helifreak.com/showpost.php?s ... stcount=84
Posté : 12 sept. 2011, 17:12
par cestb
Ah ouai, bon faut pas s'emballer non plus, c'est peut etre le premier...
Attendons de voir. Il peut aussi y avoir d'autres phénomènes présents sur toute série (ca pue quand meme...)
De toutes les facons, suis pas emmerdé, le mien est rendu en belgique, suis peut etre pas pret de le revoir...
Posté : 13 sept. 2011, 18:38
par Beni540
apparement, selon l'image de Den, il s'agit d'un controleur modifié et "reparé" qui est sensé fonctionner correctement (désignation du "2" dans Phoenix ICE 2 HV 120). Mais apparement CC n'a pas trouvé la solution au problème vu que la nouvelle version corrigée est quand meme partie en fumée... On peut le dire, ca sent le roussi, et on est pas près de voir un contro CC fonctionner comme il faut...
Faut-il aller découvrir d'autres marques?
Posté : 13 sept. 2011, 19:48
par den
En survolant le sujet sur hélifreak, on voit que deux autres sont revenus et fonctionnent, un des deux avec un bruit bizarre au départ quand même.
Posté : 13 sept. 2011, 21:34
par cestb
C'est pour ca que je dis qu'il faut attendre...
Un qui fume, ca ne veut rien dire.
S'il y en a d'autre, ca craindra...
Posté : 15 sept. 2011, 02:48
par Beni540
... vous proposez quoi comme marque d'ESC de remplacement de qualité?
Les esc d'align sont fiable? genre celui de 100A (RCE-BL100G) pour le trex 700?
Posté : 15 sept. 2011, 07:08
par cestb
Celui d'align est un 6S si je ne raconte pas de bétise donc c'est mort...
Apparemment, les hobbywing ont la cote en ce moment (j'espere ne pas me gourrer de nom)
Une copie/clone/le meme existe chez HC :
http://www.hobbyking.com/hobbyking/stor ... s_ESC.html
Posté : 17 sept. 2011, 08:21
par PaPaYoU
Beni540 a écrit :... vous proposez quoi comme marque d'ESC de remplacement de qualité?
Tu as le YGE H120
ICI
Le RCE-BL100G fonctionne en 6S tension maxi 25.2V donc pas possible avec un 700Mx qui tourne en 50V
Posté : 17 sept. 2011, 14:40
par Beni540
... vous me conseillez (même conseiller en général) d'attendre celui de CC, ou de me prendre un YGE?
Le YGE est plus fiable, vu toute l'histoire avec les CC (meme après reparations), mais au niveau de la programation, la moitié des termes me sont inconnu, sans oublié qu'il faut mettre encore 300 euros sur la table, sans compter les fdp et la carte de prog...
Posté : 17 sept. 2011, 14:49
par cestb
Regardes les hobbywing
Posté : 17 sept. 2011, 14:57
par den
Il "paraitrait" selon "certaines rumeurs" (
) que ces himodel ICE soient des clones ou rebadgages de YGE. La carte de prog est en tout cas compatible.
http://www.himodel.com/sort.php?sub2=FO&page=2
Donc peut être une solution un poil plus économique
mais je n'ai pas approfondi le sujet <_<
Posté : 17 sept. 2011, 16:05
par PaPaYoU
Ce qui me surprend le plus c'est qu'il n'y a pas de radiateur sur ces clone Ice même le 140 A en est dépourvu
Posté : 17 sept. 2011, 18:56
par den
Comme sur l'original d'ailleurs
http://radiocontrolledshop.ie/yge-brush ... oller.html
Il y en a peut être un au dos mais qui reste sous la gaine thermo.
Comme quoi pas forcément besoin d'énorme radiateur quand la chose est bien conçue.
Posté : 17 sept. 2011, 19:27
par PaPaYoU
Et le tarif est plus tôt alléchant à etudier effectivement
L'original
Le clone
Posté : 18 sept. 2011, 11:13
par cestb
Purée pourquoi le 120A coute moins cher (beaucoup moins cher) que le 100 ???
C'est etonnant et c'est tentant effectivement...
Posté : 19 sept. 2011, 20:31
par PaPaYoU
Posté : 21 sept. 2011, 12:12
par PaPaYoU
Que pensez vous du
SCORPION
Posté : 21 sept. 2011, 14:14
par Yoy24
Hooo y pète celui la... le prix aussi...
Posté : 21 sept. 2011, 14:17
par PaPaYoU
249.99 dollars soit environ 187 euro pas si cher comparé au castle
