Firmware DX8
- godjc
Firmware DX8
Les mises à jour sont dispo sur .ce site.
Pour vous insrire, il faut entrer le n° de serie de la radio, vous êtes alors averti par mail de chaque nouveau firmware.
AirWareTM Change Log
Version 2.06 (sortie le 24 September 2012)
Software Features
SpektrumTM DX8 AirWareTM Change Log
• Automatically corrects sub-trim and travel for models created in version 2.04 and earlier after prompting the user. This is functional both for models already in your radio, and for any you import from an SD card. You should always verify operation of a model when making any updates prior to flying it.
Software Corrections
• P-Link Master Trainer mode was using trainer data for channels GEAR and higher.
• When a channel is reversed the endpoint adjustment worked on the opposite side from what was expected.
• Improved French translations.
• Added SD logfile indicator to main screens.
NOTE: This change affects sub-trim and travel of existing models and ones you will import. You should double-check sub-trims and travel on any reversed control surfaces in both airplanes and helicopters when using models created in version 2.04 and earlier.
Version 2.05 (sortie le 13 août 2012)
Software Features
• Added support for GPS and High Current telemetry sensors.
• Enabled up to 32-pole motors for the brushless RPM sensor.
• Enabled SD telemetry log file
• Enabled ability to configure inactivity timer
• Enabled backlight configurability (Auto/On/Off)
• Enabled dimming control of the orange Spektrum LED for night flying
• Adjusted vibe motor RPM to be less aggressive
• Fixed bug that could reset the radio when scrolling through Mix options.
• Corrected L/R trimmer ‘forgetting’ assignment after power cycle.
• Improved translations in French and Italian screens.
• Corrected export of flap configuration.
• Corrected over-travel of flaps that could result in reversed operation at extreme deployments.
• Corrected switch change on Acro throttle cut screen when going from the initial switch selection to the edit page.
• Corrected timer to work properly in Throttle Out mode when using reversed throttle channel.
• Corrected end-point adjustability when Trainer is used as an input to a channel.
• Corrected trainer normal Master mode so that it doesn’t modify controls from the
slave. In previous versions it could reverse channels vs. what was expected.
Attention : NOTE: This change affects sub-trim and travel of existing models and ones you will import. You may need to adjust sub-trims and travel on all control surfaces in both airplanes and helicopters.
Version 2.04 (sortie le 17.11.2011)
Software Features
• Added G-Force telemetry support.
• Added “Knob” to calibration screen so users know the status as they calibrate it.
The knob neutral point was not being updated during calibration. We also corrected the criteria for centering on the sticks to improve functionality in some radios.
• The Switch Select page more accurately reflects the current switch assignment. If a wing or tail type uses a channel that a switch is on, the switch setting is changed to INH. It remains INH until manually reassigned.
• When a model is copied, the bind information for the copied model is now erased. This will allow the user to see that the model is not bound, as it will not show DSM2 or DSMX on the main screen.
• Calibration for mode changes uses the same screen as when a user manually selects calibration. This means that mode change cal requires the user to move both sticks in a + format (not like an O, X, L, or T), as well as rotate and center the knob.
• Translations – Improve/Correct translation of some terms for some German Helicopter screens. Corrected Italian translation “Alettoni.”
• Calibration – when calibrating, the knob “neutral point” was not being updated.
• Flap System – The elevon flap system bug has been corrected. The flaps now
work smoothly and move correctly for the given speed values.
• Channel Assignments – Scrolling through the wing and tail types does not
change gear or aux channel assignments until the wing or tail type is actually selected.
Version 2.03
Software Features
• Changed Monitor screen to improve perceptibility of changes in stick and trim resolution.
• Added new wing type Elevon B. This mode is used if control horn or servo positions don’t allow correct throw directions. Eliminates need to swap elevator and aileron servo leads. Also required with some trainer systems like the DX6i.
• When editing the timer configuration, any changes will cause the timer to be reset.
• After reversing the throttle channel, the screen changes to show a reminder to rebind at low throttle for safety.
• To improve the ease of adjusting travel limits for complex servo functions (swash, V-tail, etc), the Servo Setup screens now are tracking servo outputs directly.
• To avoid confusion when binding, we changed the Bind screen to show actual 11ms/22ms bind info instead of what the receiver is capable of doing.
• Enabled adjustment of the telemetry receiver voltage display bar. Adjusting the low and high setpoints (high is NOT an alarm) you are adjusting the scaling of the bar graph for Rx Voltage.
• When importing a model, a confirmation screen now appears to warn about possibility over-writing the wrong model.
• Changed telemetry menu and capabilities to enable access to future sensors.
• Users are now able to calibrate the knob and both stick in both axes. This is
done by selecting NEXT several times from the System Setup menu. Move the sticks in a “+” format, NOT in an X or O. It is important not to push the sticks to the corners.
• Flap/Elevator Smoothness – Elevator compensation travel was not smooth when there was significant trim on the elevator channel.
• Flap Overdrive – Initial flap movement could sometimes cause flaps to jump to one extreme of travel before moving to correct setting.
• Telemetry - Changed scaling for telemetry alarms Altitude & Airspeed. Fixed ‘hidden status’ screens when using models created in older versions.
• Translations – Improve/Correct translation of some terms for German, Spanish and Italian modes, particularly on the Timer and Telemetry screens.
Version 2.02
Software Upgrades
NOTE: Version 2.02 is a Factory only version.
Version 2.01 Software Corrections
DX8 SpektrumTM AirWareTM Change Log
• Language translations corrected in telemetry and helicopter screens.
• Timer screen allows access to change throttle stick position.
• Telemetry screens for PowerBox and other sensors are not shown when the
Display control is set to Inhibit.
• A model file that has the timer set to Inhibit can now be imported correctly.
• Flap system output positions are updated immediately as changes are made.
Version 2.00 Software Upgrades
• DSMX is enabled.
• DSMX/DSM2 bind mode is now shown on the main screen immediately to the
right of the Spektrum logo.
• DSMX/DSM2 mode selectable on the Frame Rate screen. Note that a DSMX
receiver is necessary for DSMX operation.
• Added support for new Telemetry sensors Airspeed, Altitude, and PowerBox.
• Receiver Voltage is now shown on the Min/Max screen.
• Telemetry menu is now a scrolling list, to improve ease of use as the number of
possible sensors increases.
• When setting the Flight Pack Voltage alarms, you can easily set the alarm points
based upon LiPo cell count, then tweak them to your preference.
• The low-level SD interface is updated to improve compatibility with PC’s.
• Mix and Gear switches can now be used in mixing functions to have the active
position either 0 or 1. These are named Mix-0/Mix-1 and Gear-0/Gear-1. The “1” option is the same as the old Mix or Gear option, as the mix function was previously active in position 1.
• The Timer Setup screen now hides information which is not related to the selected timer mode.
• In Elevon wing types, the Flap System is enabled, providing the flap function on Aux 1 and enabling proper elevator compensation. In this mode, the Aux1 channel would typically be used either as a drag brake or a spoiler.
• The Serial Number screen now includes an EXPORT function to make it simpler to enter the serial number when registering a new radio.
• Mix Switch – The Mix Switch was sometimes treated as a 3-position switch.
• Mode-Change Recalibration – When changing between Mode 1 and Mode 2, the throttle and elevator sticks were calibrated to different tolerances than during factory calibration.
• Telemetry Alarming – Corrected problem with multiple alarms on main voltage sensor inter-acting with one another.
Version 1.04 : (Sortie le 30.10.10)
Software Upgrades
Trim Center Pause When adjusting the trims through center, the pause was lengthened to allow the center position to be more easily accessed.
Knob Center Tone When adjusting the knob, it generates a center trim tone as it rotates through center.
LiPo Battery Verification Attempting to change the battery type in the Extra Settings screen from NiMH to LiPo will not be allowed until a LiPo battery is installed. This prevents the user from mistakenly selecting the LiPo battery voltage cutoff with a NiMh battery installed.
Frame Rate Defaults to 22ms- The Frame Rate now defaults to 22ms rather than 11ms. This prevents analog servo compatibility issues in the default mode.
AirWare Auto-Update To guard against inadvertently downgrading the radios AirWare, after installing version 1.04 or higher the system will rename the update file to prevent it from auto-loading in the future.
Startup Screen The startup is changed so that no inaccurate No RF Link warning is displayed.
Heli Mode Trainer Button if the Trainer button was assigned to a channel in the Switch Select screen, the channel was inactive.
Flap Trim When a Flaperon wing type was selected and the right or left trimmer was assigned to flap trim, the trim was mixed as ailerons instead of flaps. It was also not possible to deactivate flap trim once selected.
Acro Throttle Curve Pressing the CLEAR button could allow the displayed throttle curve to not match the values entered numerically.
German Timer The prompts for the German-mode throttle-based timer controls were renamed so as to be more intuitive.
Throttle = Gasstellung Throttle 1-time = Motorstart Throttle Out = Motorlaufzeit
Version 1.03 (sortie le : 08.10.10)
Software Upgrades
Heli Servo Travel Adjust In heli mode, it is now easier to set up the swash endpoints using the Servo Travel screen. The travel limit box remains on the last value that was highlight by the stick position. Centering the stick and pressing clear returns to highlighting both values.
Enhanced Telemetry Status Screen A new All-in-One telemetry screen displays Timer, RPM, Battery Volts, Temperature, Rx Volts, Frame Losses, and Holds.
Telemetry Auto-Display An Auto option in the Telemetry Settings screen will automatically advance from the main screen to the above Enhanced Telemetry screen when the timer is activated and telemetry data is available. The roller can then be used to access any of the telemetry or main screens.
SD File Navigation On the SD file navigation screen the BACK button now operates the same as selecting the <BACK> file.
Heli Mode Mix Issue In the previous version, mixing to certain channels would cause no travel.
Differential issue- In airplane mode when any dual aileron wing type was selected and a mix was created with the left aileron as a slave (crow mixing) adding differential could cause servo output errors on the aileron channels.
Model Save Corruption If there was an error while exporting a model, it could go undetected and unreported until reading the file back in.
Heli Bind Issue If a model had Expo enabled on all throttle and pitch curves, it would not bind. This is corrected.
Version 1.02
Heli Mode Model Memory Issue In previous software versions, changing the channel in the Gyro or Governor screens from the default setting to any other channel would cause the model memory to default to Model #1.
Heli Mode Limited Trim Throttle Trim didnt work below 1⁄2 trim.
Direct Model Access 10-Second Timer In some instances, the 10-second time-out
function for direct model access was applied to other screens after Direct Model Access
was used.
Improved Flap Switch Selection In Airplane mode, flap switch selection could be in
conflict in the Flap System Screen and in the Switch Select Screen. In version 1.02, the
flap switch selection is in the Flap System Screen.
Center Trim Position Mark Version 1.02 locates a trim tick-mark next to the trim
graph at center trim, allowing convenient reference when the cursor is near center.
Version 1.01
Software Upgrades
Throttle Out timer activation In the timer screen, Throttle Out has been added to the timer start options. When selected this mode uses the throttle servo output position to activate the timer rather than the throttle stick position. This is ideal for electric helicopter use as the timer can be paused when the output throttle position is at idle even though the stick may not be at low stick (like during an autorotation) plus the timer wont turn off when doing full negative pitch maneuvers in stunt mode. MIX and GEAR switches have also been added to the list of available timer switches.
Throttle Reverse Confirmation In the servo setup screen, when reversing the throttle servo, a confirmation screen is now displayed requiring a second step (confirmation) before servo output is reversed.
SD Card - improved support for low-capacity cards.
Throttle Curve Switch (airplane mode only) - the user-selected switch in the Throttle Curve screen in airplane mode only was always assigned to the Flight Mode switch. This function is now corrected.
Multi-Mixes with a Common Slave Channel - if a user had two or more mixes programmed to the same output channel, only the higher-numbered mix would be active.
Mix Trim-Include In some mixes trim include was assigned to the wrong trimmer in certain circumstances.
Internal Timer In the timer screen the internal timer for each model was not accurately calculated.
Trim Steps - When trim step sizes were changed in the Trim Setup screen, values higher than 6 would cause the trim range to decrease.
Shifting Screen - When selecting NiMH vs. LiPo battery, the bottom half of the screen would shift up or down 1 line.
Translation Errors - in French, Italian, and Spanish, the "Model Selection" menu optio was named "Special Features" and not translated.
RPM Telemetry - The displayed value for the RPM was unstable when using the brushless motor sensor. Also a phantom RPM was sometimes displayed when dashed lines should have been displayed (no recent RPM reading). A filter was added to stabilize the RPM readings.
BNF File Import - properly supports multiple languages now.
Servo Travel Adjust- When editing Servo Travel Adjust, pressing CLEAR would cause
the channel reverse to be defaulted to normal
Pour l'instant, les bugs soulevés, notamment sur Helifreak, sont corrigés rapidement. Le choix de la numérotation des mises à jour : 1.0x, laisse à penser qu'ils ont prévu d'introduire de nouvelles fonctions
Software Features
Software Features
Software Features
Version 2.03
Software Features
Version 2.02
Software Upgrades
• DSMX is enabled.
Software Upgrades
Software Upgrades
Version 1.02
was used.
Version 1.01
Software Upgrades
Modifié en dernier par godjc le 26 sept. 2012, 21:42, modifié 4 fois.
Frsky X20S
Frsky X20S
- godjc
Je commence :
Pour ma part, pas de bug particulier dans mon utilisation courante hélico.
Par contre j'attends avec impatience
- qu'ils ajoutent une option permettant de couper les bips des touches.
- La sortie du module RPM brushless qui permettra de connaitre, en temps réel, le régime du rotor.
Frsky X20S
Frsky X20S
- godjc
- godjc
Re: Firmware de la Spektrum - DX8 Les mises à Jour
Nouvelle version du firmware :
Version 2.00 : (Sortie le 09.02.11)
Software Upgrades
• DSMX is enabled.
Software Upgrades
• DSMX is enabled.
Frsky X20S
Frsky X20S
- TiTidom
Bonjour à tous
Question : lors d'une mise à jour du firmware, est ce qu'il faut sauvegarder ses modèles (sur carte SD) avant la mise à jour ou bien est ce qu'il les conserve après la maj ? (j'ai reçu ma dx8 en 1.04 donc pas encore eu l'occasion de faire de mise à jour )
TiTidom.
TiTidom.
TiTidom (92) 37 ans DX8 (v3.00 / M2) - Spot de St-Nom (Yvelines) (Accès)
QAV 400 & 540G NAZA V2 / DJI F330 OP Révo TRex 450Pro & 550E FBL
__________________________________________________________
- godjc
Salut, cela les conserve sans soucis.
Frsky X20S
Frsky X20S
- godjc
Version 2.01
Software Upgrades
Software Upgrades
Frsky X20S
Frsky X20S
Salut la compagnie...
Moi je n'arrive pas a tél...ger la mise a jour 2.01, a chaque fois il me fait un check avec le PIN et ça me dis qu'il faut que je l'envoie pour la modif DSMX......
Je suis le seul ou ça le fais chez d'autre. ?
- SmallLama
je dois bientot faire une mise a jour sur une DX8 du club :
Specter, tu as resolu ton probleme ? cela bloque t il la radio ?
pasque je veux pas faire la mise a jour et rendre la radio inutilisable :s
Alors non mise a jour non effectuée... je suis toujours en version de base... il me semble du moins...
j'ai de la chance l'importateur suisse et a deux pas de chez moi donc je vais aller faire un tour pour qu'il me la passe en DSMX et normalement après je pourrais faire la MAJ...
Mais sinon elle fonctionne parfaitement sans la MAJ... aucun souci ...
le seul point que je peux dire négatif et que si tu allume ta radio et que je branche direct la lipo sur le modèle, le bind ne ce fait pas, donc maintenant j'allume la radio avant (~2 min) et après je branche mes lipo's et depuis plus de souci...
voili voilou...
voili voilou...
Voici un article super intéressant sur la DX8. Je vous conseil de le lire attentivement.
http://mittel-aero.forumgratuit.fr/t37- ... pektrum#99" onclick="window.open(this.href);return false;
Bons vole Steve
Bons vole Steve
Si vous voulez vous rendre compte par vous-même du réel problème DX8 tapez «dx8 full negative pitch » sous http://www.google" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;, et vous verrez que nous sommes Loing d’êtres les seuls et c’est toujours le même symptôme. Nous volons et l’hélico pas de problème et tout d’un coup il passe en pleins pas négatif. Vous imaginez facilement la fin de l’histoire.
Lien de forums parlant du problème :
http://www.helifreak.com/showthread.php?t=287444
http://www.rcgroups.com/forums/showthre ... 8&page=341
Si vous avez le cœur bien accroché visualisez quelques vidéos et imaginez si votre hélico vous fonce dessus ou dans la foule !!!!!
http://www.youtube.com/watch?v=mVbiMpOn ... r_embedded
Pour ma part je ne peux plus faire confiance à Spekrtum et leurs DX8. Imaginez qu’a notre club il y à que 3 DX8 en tout et que tous les trois nous avons crashé exactement de la même façon, avec des hélicos différents, et des récepteurs différents. En plus tous les 3 nous avions des radios Spektrum avant (2* DX7 et une DX6) et nous n’avons que remplacé notre Radio par la DX8 alors que nous avons plusieurs 10 de vols avec l’ancienne !!!!!
Amicalement, Steve
PS : Je ne voudrais pas savoir qu’il y a eu un accident avec cette DX8 alors que je connaissais le PB et que j’ais fait comme si de rien n’était. Pour avoir vécu le crash je peux vous assurer que ça ma fait un choc, et heureusement que mes amis autour de moi, n’ont pas été touchés !!!!!
Amicalement, Steve
- SmallLama
aprés une heure de lecture, rien de solide....
a part un mec qui dit connaitre l'electronique et qui dit etre sur que le soucis viens de la radio il n'y a pas beaucoup de piste......
je ne vois personnne qui a contacté HH (en tous cas aucune reponse n'a été publié), personne ne sait donner l'etat du Rx apres un crash (led qui clignote), certain utilise simplment des satelittes sur des Vbar ou des BeastX (ce qui n'est pas conseillé par Spektrum)
donc cela risque d'etre long avant de connaitre le probleme.....
Arf, terrible cette affaire ... et les gaz restent actifs quand ça arrive ?
Parce que si c'est un cas de failsafe, chez Spektrum les gaz sont inhibés donc inactifs et le moteur devrait se couper ...
Vous les avez acheté ensemble vos DX8 au club ? Surement un défaut sur une série particulière.
Faudrait lister les IDs des DX8 avec ce défaut et spammer HH pour qu'ils fassent quelque chose.
M'enfin, clairement la DX8 marque une différence avec la DX7, bye bye JR ...
Pour répondre à vos questions, nous sommes trois du même club à avoir le Problème. Nous avons acheté nous radio à des moments différents (étalé sur plus de 3 mois) et dans des magasins différent. Il y en à même un qui la acheté en Angleterre.
Aucun des 3 n'ont de satellites directement connecté sur des Beast-X, nous avons tous des récepteurs Spektrum allant de AR6100 au AR7100, et nous avons tous nos hélico depuis plusieurs mois, et seul la télécommande à changée!! Vous ne trouvez pas ca bizarre que depuis le changement de la télécommande nous avons ce problème? Tous les trois pas seulement un!!!
Un de nous trois à fait quand même 3 crash avec!!!! Ce qui prouve bien que c'est reproductible. En totalité nous avons 5 crach due a cette télécommande, et les circonstances sont toujours les mêmes.
Après le crash, le récepteur ne clignote pas!!!
Lors du crash le moteur se coupe et vous n'avez plus aucune action sur les commandes.
Sur certains forums en Anglais Speckrtum répond, et ne peuvent plus nier l'affaire, ce n'est qu’une question de temps. Je ne veux en aucun cas faire de l'ombre à Spektrum, mais lorsqu'un Hélico serra partit plein pas négatif dans la foule, tout le monde sen voudra, et notre discipline en subiras les conséquences. Je continue à voler avec ma DX7, et j'en suis pleinement satisfait.
Regardez quand même cette vidéo, car pour le 5 crash que nous avons eu à notre club, ça c'est passé toujours de la même façon: http://www.youtube.com/watch?v=mVbiMpOn ... r_embedded
Nous ne somme pas des béta testeurs, surtout avec des hélicos classe 90 au bout de cette DX8!!
Amicalement, Steve
Amicalement, Steve
Initiative de consommateurs : http://dx8syndrome.eklablog.com
Il ne s'agit pas de démolir Spektrum, il s'agit qu'ils prennent leurs responsabilités et fassent le nécessaire pour assumer leur carence sur cette radio, ni plus, ni moins.
Et quand un classe 90 sera tombé dans le public ou sur un pilote, les gens qui auront fait l'autruche pourront être fier d'eux...
Gdlf
- Radio JR12X DSM2 2.4GHz
- T-REX700 : BeastX - BLS251 / JR8717 / AR7100R
- T-REX700 : HK4035-500Kv / Hacker 3D80 / DS610 / BeastX - DS650, AR7100R
- T-REX450PRO : stock sauf Kontronik Jazz et Flight Power Evo Ultra 50C et Mod batterie KDE
"the mind is like a parachute it works better when open"
YO
OK
Ça a l'air sérieux ce que tu nous dit mais je vais te faire part d'une remarque ...
- Ton site et bien et si tout cela est avéré je comprend bien la démarche...
mais il y a un peut d'incohérence...
tu dit qu'il y as pleins de vidéo et je n'en voie qu’une sur ton site...
qu’attends tu pour mètre toutes celle que tu peut trouver et ainsi étoffer tes dires...
et les témoignage que tu trouverais sur le net avec...
Pour ce qui est de les rechercher personnellement sur Googllleuuu même avec tes mots clef,
ben rien mais je suis peut être pas doué tout simplement...
PS j'ai pas de In-SpeKtrectum (facile, dessolé... )et je ne suis pas fidèle au marques...
A++
EDIT j'ai fini par trouver quelques témoignages...
c'est sur t'est pas le seul...
mais étoffe ton site...
OK
A++
Modifié en dernier par Yoy24 le 04 mai 2011, 19:32, modifié 2 fois.
- yfz59
A cote de ton club il y a peut être quelque chose qui brouille les signaux ?
Bonne hypothèse yfz59 : « A cote de ton club il y a peut être quelque chose qui brouille les signaux ? »
Nous avons craché à différent endroits et en plus en hélico seul une personne vole.
A+ Steve
A+ Steve
ce qui m'étonne c'est qu'effectivement hormis vous 3 "groupés" sur héli4 par exemple personne n'a eu le phénomène, en fait personne n'avait entendu parler de la chose avant de voir ça ici...
en tant que modo je vais pas zacher ça, ça serait de la censure de base et c'est une info ; un des intervenants ci dessus d'ailleurs dit bien qu'il vole avec sa DX7 qui le satisfait pleinement donc on n'a pas de diffamation sur Spektrum, maintenant l'info est passée et on va pas non plus étaler sur 10 pages la chose, même si on va suivre le problème pour voir ce qu'il en est.
J'ose espérer que Spektrum mettra rapidement les choses au clair et fournira une mise à jour digne de ce nom...
(pour le site, les 2 "réponses" de la marque m'ont fait sourire : "on rembourse pas envoyez en SAV" n'importe quelle marque dirait la même chose )
- renaud67
Il y a pas mal de rumeur comme quoi le AR6100 et DX8 poserait ce style de problème...(Plein pas negatif)
Spektrum répondrai que ca serait a cause d'un récepteur contre fait...
Sur 2 des vidéos ce sont des 6200 en récepteur.
Un membre de FH a aussi des problèmes avec DX8 et 6100 spektrum.
La dx8 n'a pas l'air de trop aimer les récepteurs série 6.
Est-ce que des problèmes ont été aussi constatés avec récepteurs 7000 ou 8000 ?
Edit : je vois le problème aussi avec un 7100 plus haut.
Site : Air et eau, modelisme
- godjc
Nouvelle versions du firmware :
Beta Version 2.03 Software Features
Version 2.02 Software Upgrades
Frsky X20S
Frsky X20S
- TiTidom
salut godjc
Merci pour l'info L'as tu essayé ? qu'est ce que cela change au niveau affichage ?
J'avoue que pour ma part, quand je vois "Beta" j'hésite un peu, car une fois les hélico en l'air, béta ou pas il faut arriver à les faire redescendre en un morceau
TiTidom.
TiTidom.
- godjc
Pareil, j'attends la version "stable".
Frsky X20S
Frsky X20S
- platystick
Salut tout le monde.
Je dois être mauvais mais je n'arrive pas à m'enregistrer chez spektrumrc.com.
Je choisi ma radio -> DX8 et je me trouve sur une page de login où je ne comprend pas comment faire.
Si je choisi un Username/Password ça me dit : Your login attempt was not successful. Please try again.
Un petit coup de main svp?
180cfx - T-Rex 250 pro dfc - Agile 5.5
Spektrum DX8
Spektrum DX8
- methos68
ben faut d'abord cliquer sur "Register", . d'abord tu t'enregistres et là tu choisis un user/password et des infos générales puis seulement ensuite tu peux aller sur la page de login.
Config. T-rex 450 6s - Align 450L Dominator - Logo 700
Ma Page perso
Spektrum DX8 v2.04 Phoenix RC V4
Ma Page perso
- platystick
C'est bien ce que je me dis, seulement quand je clique sur "Register" ça m'actualise la page et c'est tout...!
C'est leur site qui déconne, c'est mon IP qui déconne?
J'avoue que la je comprend pas.
Spektrum DX8
Spektrum DX8
- platystick
Ok c'est bon j'avais un problème d'affichage de compatibilité? Je connaissais pas ça.
A droite de l'adresse internet (droite du cadenas de sécurité) il y a une page brisée, en cliquant dessus ça a lancé la page pour m'enregistrer, merci ^^
Spektrum DX8
Spektrum DX8
- godjc
Bonjour, le site de spektrum semble présenter de fréquents désaccords avec IE et plus rarement chrome.
Frsky X20S
Frsky X20S
- platystick
Merci à toi ça doit être ça qui m'a bloqué, mais tout est rentré dans l'ordre, je suis inscrit et mis à jour ma TX.
Spektrum DX8
Spektrum DX8
- methos68
j'ai volé avec la version beta de la 2.03. Pas de souci à déclarer et maintenant on peut calibrer correctement les deux stiks dans les deux sens et avoir tous les neutres à 0
Ma Page perso
Ma Page perso
Bonjour a tous,
Je souhaiterai,savoir si le problème de décrochage des radio et tous autre bug (oscillation des voies, et mauvais retour au neutre).
Car j'aimerai m'acheter une DX8, mais j'ai les boules d'avoir un crash suite a une rupture de com ou autre.
est-ce que Spektrum on corriger leur PB?
Car apparament le new package que Specktrum met en vente (2 satéllite AR8000 + DX8 pour 379€) devrai être sans PB.
Merci de me confirmer cela
Cordialement.
Cordialement.
E500 Futur cadeau du neveu de ma copine
Trex 450 SE V2 FBL ALIGN 3G, tête GAUI, Swash locker Mikado, Align 3G, 3* Hitec 5065MG, Futaba S9254, 430XL Align, RCE-BL35X .
Dragonus Pro FBL, tête Mikado, Swash locker Mikado, Align 3G, 460DH, BEC ProtroniK PM30A, 3* Hitec 5065MG,Futaba S9257.
MSH Protos 500 FBL, Micro Beast X, ESC YGE 60A, Scorpion 880Kv, 3* MKS DS 9670 A+ , MKS DS 760, Lipo 6S
Blade MCPX
IMAX B6
DX8
PhoenixRC
Padawan de DanyBoy hein quoi??? Padawan de DanyBoy OKkk oKkk
Blade MCPX
IMAX B6
DX8
PhoenixRC
Tu peux y allé les yeux fermé...
si jamais il y a par ici le lien de discussion de la DX8 viewtopic.php?f=122&t=30609
Yep, tout à fait d'accord avec Specter_03, je l'ai pas encore envoyé chez HH pour la mise à jour du firmware radio et j'ai jamais eu de soucis stick/perte radio.
Pourtant je vole avec des OrangeRX et RAS !
- renaud67
La mienne marche également impecc..
elle date de la promo avec les deux récepteurs offerts..
J'avais eu les technicien en Allemagne qui m’ont confirmé qu'a priori les problèmes sont derrières eux... depuis cette version vendu avec ces deux récepteurs.
Êtes vous nombreux à utiliser le firmware 2.03 Beta ? Si oui, avez vous déjà rencontré un dysfonctionnement avec ce firmware ?
- methos68
Strictement aucun( c'est même dans ma signature). mais je ne l'utilise qu'avec des hélicos !
Ma Page perso
Ma Page perso
Voilà qui me rassure. Merci beaucoup methos68.methos68 a écrit :Strictement aucun( c'est même dans ma signature). mais je ne l'utilise qu'avec des hélicos !
- godjc
Cela fait plusieurs mois qu'il est en béta. De fait, il y a des problèmes sans quoi ils l'auraient passé en "production".
Je ne m'y risquerai pas.
Frsky X20S
Frsky X20S
